94 headlights
Old Mar 10, 2015 | 04:44 PM
antfarmer2's Avatar
antfarmer2
Default 94 headlights
Hello all brand new here I have a 1994 and the bright head lights are stuck on as the blue light is also but the fog lights work right any ideas?
Old Mar 10, 2015 | 07:33 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
so whats really the question. can you not turn off the high beams by using the turn single stalk?
Old Mar 10, 2015 | 08:16 PM
antfarmer2's Avatar
antfarmer2
Yes was working fine then not still feels good and clicks but stays on high
Old Mar 10, 2015 | 08:48 PM
Churchkey's Avatar
Churchkey
The hi/low switch is bolted to the left side of the steering column it is actuated by a rod from the TS lever. The switch mount is slotted for adjustment, move the switch up closer to the steering wheel it should operate properly. If not replace the switch.
Old Mar 10, 2015 | 09:06 PM
antfarmer2's Avatar
antfarmer2
Thank you was looking at that or it comming undone from the lever how do you get the pad off to get to it found two 7 mm so far but hard to get my big butt in there to see any pics to show how to get the pad off
Old Mar 10, 2015 | 09:33 PM
antfarmer2's Avatar
antfarmer2
Thank you all gd12165 fixed it for me with a push of a button new cibe headlights just had to turn the fog lights off thanks again
To 94 headlights
