Possible bad catalytic
Old Mar 14, 2015 | 01:07 PM
Kenabinkport's Avatar
Kenabinkport
Default Possible bad catalytic
I have a suspicion that my cat has gone bad. The car stutters at idol and putters under heavy acceleration, my fuel economy has dropped, to top it off my exhaust tips are jet black. I obviously would like to fix the issue, but I can't find any stock cats, or really any cats for that matter mainly because communist California does not like aftermarket anything. I know there are cats that would be CA legal, but I'm not sure it would be worth the effort as they won't be like the stock bolt on cats. Should I just replace the cat with a straight pipe, or go through the hastle and cost of getting a new one.
Old Mar 14, 2015 | 01:12 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
no codes? Wouldn't be guessing. Find what's really wrong and repair that
Old Mar 14, 2015 | 01:16 PM
antfarmer2's Avatar
antfarmer2
O2 sensor original?
Old Mar 14, 2015 | 01:18 PM
John A. Marker's Avatar
John A. Marker
Remove the O2 sensor before the cat and hook up a pressure gauge. If there is over 4 pounds of back pressure the cat is probably bad.
Old Mar 14, 2015 | 01:19 PM
antfarmer2's Avatar
antfarmer2
Fuel pressure and filter good?
Old Mar 14, 2015 | 01:21 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Having said that, you need to post a year (there is a difference). try plugging one side and see if you have any pressure on the other. Get the car warm and check to see if the cat (s) are hot. DIsconect the cat and check for pressure and see if it runs any better. Black tips will actually happen with good cats.
Old Mar 14, 2015 | 01:23 PM
antfarmer2's Avatar
antfarmer2
Evan plugs wires and opti need to do some looking before tossing money in it
Old Mar 14, 2015 | 01:34 PM
Klondike's Avatar
Klondike
I would check O2 sensors first to see if a connector has got pulled loose or has corrosion/bad connection in it. Or if the sensor itself is old/bad. Strange that it runs rough but shows no code yet. (post what year)
Old Mar 14, 2015 | 02:26 PM
Kenabinkport
Thank you everyone for your responses, my car is a 1993
To Possible bad catalytic
