C4 Parking Brake Relocation
Old Mar 17, 2015 | 02:45 PM
sterjess1974's Avatar
sterjess1974
Default C4 Parking Brake Relocation
I'm just curious if anyone out there has attempted to relocate their e-brake in a C4 by the center console. It would be a lot nice to access, I have a feeling it would be a major pain to do though.
Old Mar 17, 2015 | 04:30 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Once you take a good hard look at that, you will probably find out it isn't going to be an option.
Why do you think it should be moved?
The current location is completely out of the way and does not interfere with anything.
Pull the handle up to set the brake, and the handle should fall back down out of the way.
If your handle is staying in the "up" position after setting the brake, it isn't supposed to be.
Old Mar 17, 2015 | 05:20 PM
sterjess1974
I was thinking more for being able to use it while driving, being able to hit it while taking a corner to start a drift and such.
Old Mar 18, 2015 | 11:36 AM
davewhtt's Avatar
davewhtt
Old Mar 18, 2015 | 12:04 PM
Bandit's C4's Avatar
Bandit's C4
Central PA Events Coordinator
St. Jude Donor '12-'13
Ok... you want to drift using the Corvette.
Sounds like a way to burn through expensive tires....
Old Mar 18, 2015 | 12:27 PM
sterjess1974
Yep, it is. It sure is fun though. Actually I don't think my corvettes eat tires as bad as my firebird does though
Old Mar 18, 2015 | 01:09 PM
tbirdsps's Avatar
tbirdsps
I just use the accelerator. My 90 drifts just fine. LOL
Old Mar 18, 2015 | 07:41 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
This isn't a FWD. Don't need the ebrake to initiate a drift.
To C4 Parking Brake Relocation
