Cleaning Engine & Compartment
Especially, what's the best way to bring aluminum parts back to a new look? Things like A frames, A/C brackets and air pumps tend to look pretty bad after a while and I'm a stickler for a clean, shiny, new looking engine.
Rick
I dont know how to make the aluminum shine, mine is pretty dull, but clean.
C
http://aluma-brite.com/index.html
for frame members, and aluminum suspension, etc., I use 409, fantastic, simple green, or any other such cleaner, along with scotch-brite pads, wire brushes, detailing brushes, and plenty of rags, etc., etc., etc.. whenever I wash the car, I usually clean and detail some section under the hood.
Thanks to all for the input.
Rick
I pulled every aluminum part off and bead blasted, then cleared them with high temp clear. All wire harness were retaped and covered with high temp fiberglass covering in all the high temp areas. Pretty much all the nuts and bolts of motor and accessories were treated in some way. Dirt drives me nuts...
Rick
1. on smooth surfaces you can use metal polish and the aluminum will look almost like chrome.
2. A product such as Eagle 1 ETCHING wheel cleaner. Basically it creates a chemical reaction w/the aluminum, removing a thin layer, and revealing fresh aluminum. Makes the aluminum look like it just came from the factory. Easy; spry it on, let it sit a minute, hose it off. Here is a "before" and "after" pic of my rear suspension after a shot of Eagle 1 etching wheel cleaner....
Works just as well on aluminum engine parts too.
1. On smooth surfaces you can use metal polish and the aluminum will look almost like chrome.
2. A product such as eagle 1 etching wheel cleaner. Basically it creates a chemical reaction w/the aluminum, removing a thin layer, and revealing fresh aluminum. Makes the aluminum look like it just came from the factory. Easy; spry it on, let it sit a minute, hose it off. Here is a "before" and "after" pic of my rear suspension after a shot of eagle 1 etching wheel cleaner....
works just as well on aluminum engine parts too.
