I believe that you're going to find you likely need a spacer using the 10.5 @ 65 on the rears. Have you checked? Are you prepared and understand the requirements?
I haven't checked to answer your question. I am prepared to add a spacer, if needed. My friend at discount tire said it was good to go and they will fit on the rear.
What is the stock wheel width on C4 base model? 17" x ?
Correct size wheel both front and rear if the corvette is between 1988 to 1990 is 17" x 9.5" with a offset of + 54 degrees. I know this because I had to purchase new wheels so I called Corvette manufacturer in Kentucky.I hope this helps you.
I wouldn't want to pick because the 2mm is maybe irrelevant but the offset on the 9.5's that you reference is 56mm.
