92 will not start, need help
Old Mar 21, 2015 | 10:38 PM
Trider's Avatar
Trider
4th Gear
Default 92 will not start, need help
New to the Forum,
Bought a 92 Coupe a few weeks ago and drove it from Los Angeles to the Bay Area, it ran great and has since until today, went out to the garage today to start it and it tried to start and ran very rough like it was running on half of the cylinders, would turn over fine just would not start and run.
Finally ran the battery down.
Found a small puddle of gas under the drivers side exhaust.
Is it the fuel,pump and sender?
Any help would be appreciated
Doug
Old Mar 22, 2015 | 12:18 AM
antfarmer2's Avatar
antfarmer2
becareful and have fire ext ready don't want to toast it
Old Mar 22, 2015 | 11:25 PM
Trider's Avatar
Trider
4th Gear
Bump
Old Mar 22, 2015 | 11:26 PM
1993C4LT1's Avatar
1993C4LT1
I would help, but since you said there's a puddle of gas, I don't know what to tell you. Sorry
Old Mar 22, 2015 | 11:47 PM
Bandit's C4's Avatar
Bandit's C4
Central PA Events Coordinator
St. Jude Donor '12-'13
Originally Posted by Trider
New to the Forum,
Is it the fuel,pump and sender? NO
Doug
Sounds like not the lack of fuel... but the exact opposite: too much fuel on the one bank to ignite... since the 92-93 LT1 is a batch fire per bank (not sequential fire on 94-96 LT1).
Leaking injectors... would be my first guess. Second, the O2 sensor on leaking bank. Third choice - the ignition wires of the affected side - check for corrosion to the boot of the Optispark. Been known to be wrong, too.
That's when a FSM comes in handy to isolate the issues.
Here's a few threads on that subject....
https://www.corvetteforum.com/forums...aust-pipe.html
http://www.digitalcorvettes.com/foru...p/t-78563.html
http://www.ls1lt1.com/forum/lt1-%7C-...diagnosis.html
http://tech.corvettecentral.com/2008...tion-overview/
Old Mar 23, 2015 | 01:05 AM
Trider's Avatar
Trider
4th Gear
Why would there be gas under the gas tank ?
Old Mar 23, 2015 | 01:21 AM
Bandit's C4
1. Raw gas dripping from exhaust = unburnt fuel from engine cylinder(s) from several circumstances or possibilities.
2. Leaking injectors blocked open - unrestricted and uncontrolled leaking into cylinders; getting purged through exhaust manifold, catalytic converter... ultimately dripping from exhaust puddling under car.
3. A failed O2 sensor may tell the computer to enrichen the fuel ratio ultimately too much to burn... and not firing.
4. The Optispark (distributor) has two separate halves of connectors - each half to each bank of cylinders. A 'no spark' condition might be a corrosion issue in the spark wires (less likely).
5. Most Important- check the oil dipstick for signs/scent of gas contamination. Prolong running in this condition will thin out the oil possibly causing (lack of lubrication) internal damage. If gas is found mixed with in oilpan - change immediately to save engine.
Old Mar 23, 2015 | 12:19 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Where in the Bay area are you?
Old Mar 23, 2015 | 03:18 PM
Trider's Avatar
Trider
4th Gear
Stockton
To 92 will not start, need help
