Tail light issue
Old Mar 23, 2015 | 09:48 AM
kdtomczak's Avatar
kdtomczak
Default Tail light issue
So one of my tail lights (the inner right one) has gone out. It will illuminate when I press the brakes or put my right turn signal on...
I have no clue what this means. Obviously the bulb is working then right?
Old Mar 23, 2015 | 10:06 AM
kenpeindl's Avatar
kenpeindl
There are two filaments in the the bulb. One is for the running light (tail light) and the other is, a somewhat brighter one, for the brake/turn signal.
You will need to replace the bulb.
Old Mar 23, 2015 | 10:11 AM
antfarmer2's Avatar
antfarmer2
I have had my vette for over ten years and never replace a bulb on the back so really don't know but some bulbs have double filements one for brakes and turn and one for light sounds like that is your case replace the bulb one bad filement
Old Mar 23, 2015 | 11:42 AM
kdtomczak's Avatar
kdtomczak
i've replaced the bulb already. Originally, the light didn't work at all. Now that I've replaced the bulb...just the blinker and brake works.
Old Mar 23, 2015 | 11:50 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
You wouldn't be the first guy who has replaced the taillight bulb with one that was, itself, defective.
Any time I put a new bulb in any of my vehicles/trailers, I test it before installing.
Old Mar 23, 2015 | 12:04 PM
kenpeindl's Avatar
kenpeindl
I would check the socket for any corrosion. The correct bulb I believe is a 3057LL.
Old Mar 23, 2015 | 03:56 PM
WW7's Avatar
WW7
When I replaced my bulbs, the sockets all had corrosion in them...I swirled some steel wool in the socket before putting in the new bulbs.....WW
Old Mar 24, 2015 | 08:56 AM
kdtomczak's Avatar
kdtomczak
I took the bulb out and checked for it. There was a lot of yellow gunk. I removed it all and that got it to work :-D ! In the process though, I warped one of the screw head that goes in the lens. hoping the bulb doesn't go out anytime soon now.
Old Mar 24, 2015 | 04:09 PM
tbirdsps's Avatar
tbirdsps
That yellow gunk used to be white dielectric grease that the factory used when assembling.
Old Mar 24, 2015 | 04:33 PM
kdtomczak's Avatar
kdtomczak
Is it bad that i removed alot of it?
Old Mar 24, 2015 | 05:30 PM
Klondike's Avatar
Klondike
You can get small tubes of dielectric grease at any auto parts store. It is used on sparkpug terminals, light bulb sockets and other electrical connectors to keep moisture out. Moisture in an electrical connector = corrosion. It's also good for rubber weather seals around doors.
Old Mar 24, 2015 | 05:57 PM
gerardvg's Avatar
gerardvg
Not hard on the 91-96.
unscrew the two screws holding the lens on, pull the lens off and replace the globe. Re assemble all done in no time.
I know I have done it the hard way before realizing the lens comes of.
Old Mar 24, 2015 | 07:14 PM
MaxDaemon's Avatar
MaxDaemon
I replaced all four at once, figuring as long as I was going through the pain (literally) of doing it, I'd make sure I didn't have to do it AGAIN. Sure enough, one of my brand spanking new Chinese bulbs was out in two weeks.
To Tail light issue
