HID headlights
My F250 has hids in the stock headlight housings and has a nice clean cutoff line. I used to get flashed with the stock headlights. With the heads I don't.
The first pic is hids with normal housings on my truck.
The second pic is from the vette on low beam also.
A clean cutoff line is good but even high quality Projectors have drawbacks
An HID bulb is merely a light source, albeit a brighter, cleaner source.
The apparatus that makes it more focused and less obtrusive is what gives an HID bulb a certified field of light is the Projector housing. without it all you have is the unfocused reflection most OEM housings create. Which is what everyone hates and works poorly.
But there is a few problems even when using a high quality Projector. If this member with the Ford or someone would kindly take a night shot with the SIDE of their vehicle within 5' of a wall directly beside the passenger side approximating what your own vehicle headlight pattern is and how it blinds a driver as you pass on a two lane highway you'll see the glaring blindness even a DOT certified Projector creates. It's a tradeoff, creating a much cleaner and focused straight ahead pattern allowing better driver vision but the cutoff pattern on the right hand (shoulder side ) still creates a blinding issue
But there is a few problems even when using a high quality Projector. If this member with the Ford or someone would kindly take a night shot with their vehicle within 5' of a wall directly beside the passenger side approximating what your own vehicle headlight pattern is and how it blinds a driver as you pass on a two lane highway you'll see the glaring blindness even a DOT certified Projector creates
That line is cleaner than the factory halogen bulbs were doing. Just with the factory bulbs I had other vehicles flashing for me to dim my lights but they were already on low. With the hids I haven't been flashed any.
Park up beside a wall (5-6' away) on the passenger side and see how high the light pattern shines.
Light patterns of all Projector lights is set to illuminate higher on the passenger side to highlight any objects on the the shoulder of the road, but unfortunately gets annoyingly high up close to drivers right beside you
Even though the light pattern shows a clean low pattern to oncoming cars it can be highly obtrusive to cars you pass in city or rural driving conditions
FWIW; True gauge of any auto lighting system is best viewed on a flat level dry surface against a flat wall 20-30' away and 20-30' wide in area void of other lighting like street lights etc.
All out, best viewed at least 30' - 50' away.
would like to see this too
I have had hi\lo H4 hid lights on my vette for around a year, yes they are illegal here in Australia as well.
I aimed them on the low side and never had any problems, i even checked how they looked doing a driveby in my company car.
No glare issues they have a shield over the hid bulb with cutouts to work with H4 lights, i got sick of the failures 2x ballasts and 1x hid light.
It is a weekend car so very little use, they are fantastic very bright great for night driving.
I went back to H4 but 140w high 100w low beam, i just live with them and make sure i let the globes cool down before closing the headlight doors. The early headlight doors close with a heavy thud, doing it like that i have no problem with fillament breakage.
It is very easy for the Police to find who uses HID, anyone who has used them can spot them. Big fines and unroadworthy sticker waiting for those wanting to use them without the correct projectors.
Albeit a problem may be lack of room in the rear of the C4 housing. LED bulb kits are deeper than OEM but LED's quite possibly could work using way less amperage than H4 Tungsten and use OEM standard gauge wiring without hurting the wiring harness.
Also LED's don't suffer the dreaded HID flicker with most aftermarket HID kits
Better yet a complete LED Housing that's plug and play. Very accurate and < 1/2 the weight
http://www.ebay.com/itm/Truck-Lite-2...-/371296916066
