Water pump replacement question
Old Mar 31, 2015 | 01:14 PM
westman's Avatar
westman
Default Water pump replacement question
I need to replace the water pump in my 94 base model corvette. ACDelco has two different pumps listed for my vehicle, 251-554 and 252-699. Not sure which one to get. Does anyone have a recommendations or know the difference?
Old Mar 31, 2015 | 01:47 PM
davewhtt's Avatar
davewhtt
Same as my 93 i believe. The #54 is closer to the OEM with better? impeller i think. The other will work and both are AC Delco so...
Old Mar 31, 2015 | 06:25 PM
westman's Avatar
westman
Thanks!
Old Mar 31, 2015 | 06:40 PM
antfarmer2's Avatar
antfarmer2
Just did mine did not offer any choices if you can look at them side by side and see don't get your opti wet if the pump was leaking or a old opti might think about replaceing your already there and the wires too need to move the power steering pump forward to get them through
To Water pump replacement question
