94 Sawblades on my 63 Nova
I finally got a day off with good weather.
I took the stock wheels off my 94 Corvette, got new tires and put them on my Nova.
Fronts are 17x8.5, rear are 17x9.5. Tires are 245/45/17(f) & 275/40/17(r).
I have wheel tubs put in, mounted to the frame. That gave me about 3" more room. Because of the tubs, I had to move the gas door back a few inches keep the tire from touching it. The rearend is about 60" hub to hub.
The front end is a Scott's set-up with 2" dropped spindles.(3" drop in the rear) I had to add 1" wheel adapters to the front to get the right clearance in the wheel wells.
Wilwood disk brakes all around. PS, PB, coil-overs up front & Caltrac arms on multi-leafs on the rear.
355ci SBC mated to a 94 Corvette ZF6 speed manual tranny. It has 2 overdrives to help tame the 4.11s in the narrowed 12 bolt.(1900rpm @ 70mph)
Edelbrock Air-Gap intake & 750 carb, Edelbrock heads, forged SpeedPro flat-top pistons, Crane cam, headers, NOS Cheater system(150 shot). New Painless wiring harness throughuot the whole car. Sylvania Silver Star headlights & LED tail lights. Pioneer stereo + 500w amp. Seats from 2007 Chevy TrailBlazer SS. Autometer gauges, air/fuel gauge & HUD speedo.
That's about it. Still a work in progress. I've owned it since 1991. It's been under water up to the windshield twice & got hit by a fire engine in my driveway, too. Originally gold w/ fawn interior, now Seafoam Green w/ black insides.
A "post sedan" in '63 I believe would still have been a Chevy II, yours appears to have the post and drip rails "blacked out". I believe I'd hang the CHEVY II "moniker" on it.
** I might try swapping them side to side and see if maybe they present themselves a little differently on the 'ole shoe-box. I realize they're mounted correctly but it might be both more appealing and certainly more conversational when you came across a C4 owner that understood.
I had one like that when I met my wife.(She was a lot easier to impress back then.) Mine had the tiny 194 cu.in. straight 6 with a 2 speed powerglide. Got a lot of good miles out of that little car.
Very tastefully done! I Like it.
That is a good look! I wonder how those would look on a Chevy S10.
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
I believe the "Nova" was a certain model of the Chevy II, which that car is.
The Corvette wheels don't work as well on the Chevy II as they did on the Corvette.
I understand the wheels the OP chose because it's what he had, the saw-blades don't work as well as they do on some others and I believe he painted saw-blades would have done much better. Maybe even being done in "car color".
