Coolant Question
Old Aug 12, 2002 | 06:26 PM
oldtimer's Avatar
oldtimer
Default Coolant Question
I have a question concerning refilling the cooling system for my 1992 C4.
I purchased a Hayes Repair Manual and it states to"Open the bleed screws on the throttle body and bypass hose for 1992 and later models"before filling the radiator surge tank. I must be blind I dont see these bleed screws or i dont know what to look for. If anyone could point me in the right direction it would be much appreciated.
Thanks!!
Old Aug 12, 2002 | 07:00 PM
konroh's Avatar
konroh
Default Re: Coolant Question (oldtimer)
I will be doing the same thing as soon as i get my electric water pump on so I am interested in knowing exactly how to do this too...anyone?
Old Aug 12, 2002 | 09:34 PM
red-y's Avatar
red-y
On the 93 the bleed screw is just before the hose connection that goes to the bottom of the radiator on the passanger side. :chevy
Old Aug 12, 2002 | 09:59 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Re: Coolant Question (red-y)
BYPASS the TB and then you wont have to deal with it... :lol: :cheers:
Old Aug 12, 2002 | 11:54 PM
C4Crazy787's Avatar
C4Crazy787
The screws are brass and slotted . Before you open them make sure to stuff some rags under them .You do not want coolant to get down to the Opti-spark. :seeya :flag
Old Aug 13, 2002 | 05:15 PM
oldtimer's Avatar
oldtimer
Default Re: Coolant Question (C4Crazy787)
I located the brass screws. Thanks for the advise on covering the spark box. Thanks Again!!
Old Aug 14, 2002 | 05:15 PM
oldtimer's Avatar
oldtimer
Default Re: Coolant Question (konroh)
The bleed screws are brass. One is located on the passenger side near the top portion of the hose that goes to the lower radiator opening. The other is on the drivers side located were the small outlet pipe goes into the throttle body.
To Coolant Question
