tires
Old Apr 6, 2015 | 09:32 AM
rat123's Avatar
rat123
Default tires
Hi
I have a 1984 corvette
will these tires and rims work Corvette saw blade rims/tires275/40R17 Cooper Zeon
thanks
Old Apr 6, 2015 | 10:33 AM
DinoBob's Avatar
DinoBob
You will need spacers to compensate for the 18mm difference in offset. Otherwise it is a match made in heaven as the overall diameter is nearly identical. Go for it!
Old Apr 6, 2015 | 10:39 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
The short answer is yes.
But the offsets are different so the sawblades will sit inboard from where your originals sit. It may look a little funny. To correct the offset difference a 3/4" adapter is needed. Many people use a 1" with no problems. I used a 1.25" on my '85 and it worked fine with the 8.5" front 9.5" rear. I think the 1.25" would have been too much on the fronts if I was using the 9.5" fronts.
Good luck.
Old Apr 6, 2015 | 10:45 AM
rat123's Avatar
rat123
Hi
This is what the guy wrote 4 Corvette saw blade rims/tires, both in very good condition.
Tires are Cooper Zeon 2XS. They fit many other vehicles,
Front and Rear are 17"x9.5" 56"" (7.4" backspacing)
thanks
I'm new at corvettes
and I own a 1984
Good luck.
Old Apr 6, 2015 | 01:54 PM
1984Z51auto's Avatar
1984Z51auto
The major Corvette venders have wheel "adapters" for early C4s that allow this mod. An adapter has its own studs where a spacer just moves the wheel out on the existing studs. The adapter is my choice for strength and safety if you have a lot of power or if you auto-cross.
Old Apr 6, 2015 | 02:32 PM
rat123's Avatar
rat123
So what size would I need (thickness). And do you have any info on them
thanks
Old Apr 6, 2015 | 02:58 PM
DinoBob's Avatar
DinoBob
Google this a bit and you will find a set that works. 38mm, 56mm, offset, Corvette, adapter are your search terms.
Old Apr 6, 2015 | 05:58 PM
rat123's Avatar
rat123
Hi
What would you recommend. What offset would you recommend
thanks
Old Apr 7, 2015 | 08:57 PM
1984Z51auto
thanks
As I said, the major vendors like Forum Vendor Corvette America have Wheel Adaptor Kits to put late C4 wheels on early C4s. There is only one thickness offered. See page 90 (Part Number 22110) of their 1984-2014 Catalog or check the part number through the vendor section
To tires
