Coolant leak?
Old Apr 15, 2015 | 08:11 PM
Viper588's Avatar
Viper588
Default Coolant leak?
Hey guys got home today after a quick 20 minute drive and i heard some liquid dripping on the exhaust and burning up. I got under neath and found a drip on the drivers side of the car right above the CAT. Whats confusing me is that the liquid looks to be clear and it does not look or smell like coolant, it seems to just be water. I though maybe there was some pooled rain water that's dripping down, but i dont see why it would be a consistent drip after a drive, but thought maybe its been dripping and just didn't notice it because the exhaust wasn't hot to hear it burn off? Are there any common hoses or anything that leaks in that general area to check? Here's a quick video i tried to take but it didn't come out that clear since its getting dark.
http://www.dailymotion.com/video/x2mt02r
edit- 92 C4 56k miles LT1
Old Apr 15, 2015 | 08:14 PM
antfarmer2's Avatar
antfarmer2
Lol were you running your a/c I wonder if your drains were plugged up could it fill up? There is a drain hose behind the battery
Old Apr 15, 2015 | 08:26 PM
Viper588's Avatar
Viper588
Just went out to make sure but neither heat or a/c were used. Might check the drain hose tomorrow though just to rule it out, thanks!
Old Apr 15, 2015 | 08:29 PM
antfarmer2's Avatar
antfarmer2
I belive there are three that one has a hose the one one the otherside does not just a hole above your pipe the center one don't know yet
On my 94 I can open the hood and reach in from the side and grab the hose without takeing anything off pull the hose up and see
Old Apr 15, 2015 | 10:38 PM
higgyburners's Avatar
higgyburners
I believe in the Beer Fairy
St. Jude Donor '15,'19
you should use another website for the video, I had to listen to adds and it plays slow so i had to escape.
Old Apr 16, 2015 | 01:10 PM
Viper588's Avatar
Viper588
So this morning the leak was not there, I did check the drain line and was able to reach in and access it like you said and it was gunked up pretty bad and a steady flow of water came out after I cleared it! So at this point I'm assuming that's where the leak was coming from until it occurs again! Thanks for the help!
Old Apr 16, 2015 | 01:11 PM
Viper588's Avatar
Viper588
Sorry about that! The site I normally use to host stuff make you wait 3 hours before the video could be accessed so I had to try that one.
Old Apr 16, 2015 | 01:25 PM
antfarmer2's Avatar
antfarmer2
Good deal only two more to go get them before your carpet gets wet
Old Apr 16, 2015 | 03:04 PM
Viper588's Avatar
Viper588
actually now that you mention it when i replaced my passenger side speaker the carpet was dry but the insulation under it was damp/wet. Ive been trying to track down where the water came from. Perhaps thats where lol Where is the drain in that area?!
Old Apr 16, 2015 | 08:54 PM
antfarmer2's Avatar
antfarmer2
Get under the car and look just above the right exuast pipe by the front just a hole no hose
To Coolant leak?
