95 LT1 overheating
if you pull your thermostat do NOT let it get your opti wet
It could also be a slow leak, or just enough of one to bring air into the system.
How do I test to see if it is the water pump?
If the radiator and A/C condenser are free of dirt and debris, then check the coolant level. With the engine cold. remove the pressure cap and start the engine. Let it idle and watch the coolant level. When the 'stat opens, you will see coolant circulating in the tank.
Run the engine up to about 1200 RPM and add coolant as necessary so that the level is at the bottom of the filler neck. Then replace the radiator cap and keep an eye on the temps. Are the coolant hoses original? You may have a lower hose that is collapsing
If you have not done a cooling system service, it's probably time to do so. You can do a search in the C4 Tech section for the procedure. Not too difficult to do and it is a good idea to remove the knock sensors to get all of the old coolant out.
I would suggest a new thermostat and replace both radiator hoses. Maybe even a new pressure cap if yours is original to the car. The GM service manuals do not recommend the use of cooling system cleaners; the FSM says to drain the coolant, fill with water and get to operating temp then do that two more times. Then you can add a 50-50 mix of Dexcool.
Definitely don't get any coolant on the OptiSpark
You can just cover it with aluminum foil as you are doing the 'stat and filling the system when you have the bleed valve open.
You can just cover it with aluminum foil as you are doing the 'stat and filling the system when you have the bleed valve open.I did remove the cap, but it flowed right out after about 15 seconds, the temp was about 145ish when I did that
