c4 overheating
Old Apr 19, 2015 | 04:25 PM
Jkerps01's Avatar
Jkerps01
5th Gear
Default c4 overheating
I have an 1987. The issue I am having with it is it likes to climb up to 240 degrees, possibly hotter, I always shut the car off before it gets to much hotter. In the past I had issues with the overheating. I had replaced the radiator fan and that's still working. I don't see any obstructions on it or anything like that. I looked under the front of the car, and there doesn't seem anything to be blocking the radiator when from air flow. While it's idling it climbs up to 240, that's before the oil temp even comes close to catching up. Leaving the oil around 165 before I shut off the car. I just recently replaced the upper radiator hose cause it was leaking, but the car is still overheating. I refilled the coolant level, and I've taken out the thermostat, to see if it was just the thermostat, to let it run continuously open.
So my question is could it be possibly a bad sensor? The water pump, or something else? Would the AC harness if it kicked on, cause it to get that high? Also it's kind of idiling around 11 where it used to idle lower than that before.
Old Apr 19, 2015 | 04:32 PM
antfarmer2's Avatar
antfarmer2
Take off the top piece of the fan shrould and see how much crap is behind the radiator and for the idle find your vacuume leak
Old Apr 19, 2015 | 05:35 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
At least put a new thermostat in. If it still gets too hot, your radiator most likely looks like this. The only way to clean it right is to take it out
Old Apr 19, 2015 | 07:43 PM
Jkerps01's Avatar
Jkerps01
5th Gear
The radiator is less than a year old.
Old Apr 19, 2015 | 07:49 PM
antfarmer2's Avatar
antfarmer2
Does not matter a plastic bag can get behind it in a anytime
Old Apr 20, 2015 | 12:58 AM
Cliff Harris's Avatar
Cliff Harris
Sounds like the coolant temperature sensor on the front of the intake manifold is bad (or the connector/wiring associated with it). You might have a corroded pin in the connector. If the ECM thinks the coolant is cold it won't turn on the cooling fan.
Does the cooling fan run when the engine gets hot? Do you have the auxiliary fan (in front of the A/C condenser)? If so, that should come on at 238°, which would be in the neighborhood of the temperatures you're reporting.
Old Apr 20, 2015 | 08:48 AM
1stvetteguy's Avatar
1stvetteguy
I am going through this right now with my 95, I am hopeful its just a bad thermostat and not the expensive water pump! Good luck!
Old Apr 20, 2015 | 12:20 PM
88vetteL98's Avatar
88vetteL98
I have the same problem with my '88 coupe - radiator is clear and no frontal debris. Fan is working..
Old Apr 20, 2015 | 07:47 PM
ex-x-fire's Avatar
ex-x-fire
When the cooling fan is running, see if a paper towel or rag will stick to the a/c condenser.
Old Apr 21, 2015 | 11:54 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Did any of you guys "burp" your systems completely?
Old Apr 21, 2015 | 12:01 PM
antfarmer2's Avatar
antfarmer2
I used the bleeders once now I just jack up the right rear side and let the air out on my 94 don't want to take a chance with the opti
Old Apr 21, 2015 | 12:05 PM
JrRifleCoach
Do a search and read. There are ten pages of "overheating" posts to choose from.
Here's my point, there are YEARS of experience in this forum's history.
And the SEARCH feature is the only way to access this gold mine.
Simply starting a new thread only scrapes the current surface of knowledge.
And most of this knowledge is speculation from noobs.
Maybe not in this thread, since the problem here is very common in C4's.
Goto search and use the advanced feature for searching "topics" not the default.
Old Apr 22, 2015 | 03:21 PM
Jkerps01's Avatar
Jkerps01
5th Gear
Default Checked
Checked behind the fan shroud and what not. No trash. Nothing blocking the radiator and after I replaced the fan behind the radiator it runs whenever the car is on. It's done that since I have installed that. The car used to stay about 160's to 180's. About to try and burp it. See if that helps
Old Apr 22, 2015 | 06:56 PM
Cruisinfanatic
even 1 qt low on fluid will cause to run hot and or have bad heat
To c4 overheating
