From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Fuse Panel Troubleshooting Tip
Periodically, I have an electrical event that first requires this step.
The four large fuses on the R/H side will dislodge.
Push them all back into place and check again.
You can test a blade fuse without removing it. Each blade or mini blade fuse has two test points. One on either side of the numbers.
With the key on and normal power to the car applied; you can ground the negative lead of your DVM or test to the chassis and then take a reading from each side of the fuse. If one side has power and the other does not, then the fuse is most likely blown.
