I'm replacing my headliner and noticed this rear corner of the frame is not attached to the fiberglass outer skin. I don't see any mechanical fasteners missing. How does this attach?
Many years ago i went though this issue, my fibrglass targa seperating at the rear corners.
I had it repaired at least 3 times, they all did not last.....
I think the only way is to completely remove the fibreglass and clean the contact areas, then use the correct bonding material.
I do not know what the best is.
After a few months i noticed a buble on each side, after one bubble popped open i noticed some $#@* put self tapping screws to hold the skin down onto the frame. That was the end of that targa roof.
I purchased a replacement roof after the last "fix" by some #@!*& ruined my targa roof.
So be careful what body shop you take that roof to be repaired.
epoxy maybe JB weld have to make sure what is best.
Yup, just did this yesterday....worked like a charm. Make sure you get the epoxy well into the part where the frame meets the acrylic top. I used ice cream sticks that I filed down to almost a point to make sure I got it in there. I then made sure that there was a tight seal by putting weight on the top to weigh it down for 12 hours.
My top is starting to separate too. I noticed it first because it caused a lot of squeaking noises when driving. If you guys think that the JB weld will work, then I'll try it out as well.
May be better with epoxy I would do some research on the right one.
JB Weld will work for a little while, but it gets too hard and will crack. I repaired my top several years ago, and it's fine. Take your top to a windshield repair shop. They have the right stuff!! You only need a little bit, so they should be able to fix your top with the leftover adhesive from a windshield replacement job. I used Betaseal U-418. It cures with a little resilience, so the top and frame can flex with the temperature extremes without cracking.
