About to attempt stereo install
I've heard horror stories. Any advice?
Thanks!
Thanks!
To run the speaker and adapter wires to the rear, I removed the passenger seat and the center console. That allowed me to pull the carpet back and run the wires along the tunnel. There is a hole in the metal behind the passenger seat that wire is fed through to the rear compartment. I was able to feed the adapter wire through this hole. I ran the speaker wires under the carpeting to the speaker enclosures.
Can be a little time consuming, but all-in-all, a fairly straight-forward job.
How long did it take?
Any snags?
Thanks again!
I put a deck in mine and I have the SYS flash every few seconds. I read somewhere once that you just have to put a resistor in line?
I'm just now getting back into actually doing things on my car since I have so many other projects. My parents owned it for a few years and then I traded them a running car for it after the optispark went out on them for a second time and they didn't want to pay another $1500 for someone to fix it.
An answer to my question would be appreciated though and not a "do a search" reply
I've also heard about some type of an in-line resistor. I've heard so much contradicting info on what's necessary I'm just not sure. That's why I'm so grateful to hear from some guys that have actually done it themselves.
Just do what I do, jump in and figure it out.
I spent probably 3 hours researching my heater core replacement prior to loosening one screw, and it was time well spent.
You will need to run the resistor so you sys light will not flash. There is a thread on that do a search. I have heard that if you have automatic climate control you do not have to resistor but I have not tried it.
I haven't been on here long enough to know what threads actually contain the correct information and the threads like this one where there is just a couple of confused newbies and only a couple half answers from seniors that use the "search" cop out
I've never done a C4 but I did my C5 the same way and it worked out fine. I also found another adapter to adjust the base for the bose speakers.
Best advice I have is do your wiring correct use heat shrink and solder the wires. I just had my Bose amp repaired and add an I pod connection had these guys do it never sounded better.
http://www.carstereohelp.com/corvette.htm
Try this link out.
http://www.corvetteforum.net/c4/dave8476/index4.shtml
If that does not help you out then just ask again. No need to get defensive or rude.
And BTW that was found by doing a search.
https://www.google.com/search?num=30&espv=2&q=c4+corvette+sys+f lashing+stereo&oq=c4+corvette+sys+flashi ng+stereo&gs_l=serp.3...623122.631108.0. 631349.22.17.0.5.5.0.156.1915.0j15.15.0. ...0...1c.1.64.serp..8.14.1201.WBZf5U5vj Es
Rick
I used the original boxes but had to make some plywood adapters to mount the speakers. I also ran all new 16 gauge speaker wire to all speakers and a 8 gauge power wire straight to the battery.
The 89s don't have anything behind the passenger seat and my Metra adaptor was useless. I cut and spliced the wires I needed from the old head unit plug and just used the new ones wiring harness.
I installed the power amp under the passenger seat and tried to arrange the mass of wires running to it in a neat, orderly fashion using lots of tie wraps and wire loom.
Rick
Rick
The Metra harness has a wiring diagram with it. Prior to pulling anything out of the car, I made all of the connections between the Metra harness and the pigtail that came with the stereo (Solder and heat shrink of course). Since you are using your own speakers, you won't need to connect the speaker inputs.
Next, I removed the old head unit. Before installing the new unit, I had to trim off some of the mounting bracket in the back. This is a plastic bracket, so cutting it off wasn't difficult. This was necessary to give the new head unit enough room to be slid all the way in. (btw, I used a double din unit from Crutchfield).
I then ran the Metra harness and rear speaker wires under the carpet along the tunnel (after removing the drivers seat and console cover). The metra harness went through the hole behind the drivers seat and into the rear compartment. The speaker wires went under the carpet behind both seats and then along the side to each speaker.
The metra harness connects directly to the harness that plugs into the receiver. I removed the reciever since it was no longer connected to anything. The Metra harness is about 10 ft longer than necessary, so you will have to figure out what to do with the extra cable.
I ran the front speaker wires under the front carpet to the front speaker enclosures. Removing the front speaker enclosures is pretty easy. You have to remove a few trim pieces and the enclosure cover.
Finally, I connected the head unit, slid it in place, used the mounting brackets supplied with the mounting kit to secure the head unit in place. Put everything back in place. Enjoyed the stereo and regretted that I didn't install a sub woofer and amp.
