84 c4
Old May 31, 2015 | 06:55 PM
snezster's Avatar
snezster
5th Gear
Default 84 c4
Yes I have. I pluged the two return lines and filled it with fluid and left it over night. No leaks. This only happens when the car is driven. you can leave it idling for days and it will not leak. As soon as you take off in it, it sling fluid all over the hood, the motor, the cross member, it very frustrating.
Old May 31, 2015 | 08:00 PM
Pa'svette's Avatar
Pa'svette
St. Jude Donor '16-'17-'18,'19
With the car running have someone turn the wheels back and forth while you check for leaks. Could be the steering rack.
Pa
Old May 31, 2015 | 08:27 PM
antfarmer2's Avatar
antfarmer2
Pa
guessing this is power steering fluid .........maybe a bad cap.
Old Jun 1, 2015 | 09:55 AM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
In the future, don't post two threads on the same subject. I'll close this one down and leave the other open.
To 84 c4
