Paging Scorp>>>>>
Old Aug 16, 2002 | 02:38 PM
USPRIDE's Avatar
USPRIDE
Default Block Off kit for Cold start injector
I was wondering where the best place to get one of these would be and how much they might cost.
Thanks!!!
[Modified by USPRIDE, 12:53 PM 8/16/2002]
scorp508's Avatar
scorp508
I'm sorry, I actually got it from a forum member. Accel sells an expensive kit. :( I believe you can obtain them from Lingenfelter for cheaper money.
Old Aug 16, 2002 | 02:52 PM
Ezgoin721's Avatar
Ezgoin721
Default Re: Paging Scorp>>>>> (USPRIDE)
FYI, my superram base came with no cold start injector port, but the tough thing to find was the fuel rail cap. To get it from Accel was someting like $50 and came with a kit that I assume had a plug for the manifold too. I talked Lingenfelter into buying a box of the fuel rail caps and then bought just the cap from them for like $10. I'm not sure, but I think you could find a plug to fill the manifold port at most any auto parts store, but call LPE about the fuel rail. DOn't try and jury rig the fuel rail! The last thing you want is a fuel leak on top of your engine! :eek:
Old Aug 16, 2002 | 03:03 PM
USPRIDE's Avatar
USPRIDE
Default Re: Paging Scorp>>>>> (Ezgoin721)
Thanks for the replies everyone! I appreciate it! :cool:
Old Aug 16, 2002 | 03:26 PM
-=Jeff=-'s Avatar
-=Jeff=-
Accel PN 74820
EDIT..
Summit PN ACC-74820 $61.69 at Summit.. but is listed as B/O
Jegs PN 310-74820, but notes it is a special order item and you must call.
[Modified by -=Jeff=-, 1:28 PM 8/16/2002]
To Paging Scorp>>>>>
