war dept slammed the door too hard at the American Legion today, now passenger door opens from the inside, not outside. Is it just a rod that fell off? any easy fixes? did a lot of work on the car, never took the door panels off.....
Sounds like your going to not hard just take your time and be careful don't want to break anything else.
Same thing happened to my 85. There is a plastic clip that secures the rod to the door handle mechanism. I didn't fix it myself but watched my mechanic do the job and it was a bear. He had to modify a screw driver to get up to the area. Tight quarters, Got the clips from Corvette Central.
I remember there are two different clips and CC wasn't sure which was the correct one so I bought both. 2.50 ea.
crap!! I thought it wouldn't be easy....might be the time to get a set of new fasteners for the door and that piece that supposed to silence the door....time to break out the fsm.....
Here is a tip. After you get the door panel off use a mirror and flashlight to see what your dealing with. While installing the new clip you might as well be blindfolded.
