Fuel issue
Old Jun 3, 2015 | 10:21 PM
86corvetteguy's Avatar
86corvetteguy
Default Fuel issue
I am working on a 86 corvette. To let you know I have a new fuel pump, fuel filter, and fuel injectors. It runs great as long as it as a full tank of gas but when it get to about a quarter tank it runs horrible. It seems like it's not getting any gas. It almost stalls and acts horrible. What would cause this? I hate having to fill up everything I get to half a tank. Plus what would cause the corvette to get bad fuel mileage? What should be my average that I should be getting?? Thank you
Old Jun 3, 2015 | 10:28 PM
antfarmer2's Avatar
antfarmer2
I did not see a fuel pressure regulator in your fuel system rebuild that could kill your mileage smell your oil for fuel. There is a little tray thing in the bottom of your fuel tank that will cause the other problem if it breaks loose. Can't remember what's called.
Old Jun 3, 2015 | 10:30 PM
86corvetteguy
I have replace the fuel regulator. What's the tray?
Old Jun 3, 2015 | 10:41 PM
antfarmer2's Avatar
antfarmer2
Some sort of baffle to keep the gas in place. Can you put a pressure gauge on it and report back on pressure and how long it holds after shutting off?
Old Jun 3, 2015 | 10:43 PM
86corvetteguy
I've done that it keeps for along time after its turned of the pressure is about 40-42
Old Jun 4, 2015 | 01:14 AM
Cliff Harris's Avatar
Cliff Harris
Sounds like your pulsator is not making a good connection between the fuel pump and the fuel delivery pipe (the one that goes up to the engine).
Some people replace the pulsator with a length of hose. If the hose is not SUBMERSIBLE it will dissolve in the fuel and cause this problem. You need some of this stuff:
http://www.amazon.com/Gates-27093-Fu...ible+fuel+line
To Fuel issue
