question
Old Jun 10, 2015 | 03:39 PM
jwebster2's Avatar
jwebster2
4th Gear
Default question
I have an 87 that recently has had the accelerator stick, almost as if the cruise control is on. When I remove my foot from the gas pedal it either maintains the speed I was going or sometimes begins to accelerate. Tapping the brake fixes the problem. I have tried using the cruise and then turning it off hoping that would solve the problem but it doesn't.
Old Jun 10, 2015 | 06:08 PM
don hall's Avatar
don hall
Try lubricating the accelerator mechanism in the engine compartment, and all other cable connections.
May not solve the problem, but it is a simple, and cheap start.
Old Jun 10, 2015 | 06:39 PM
antfarmer2's Avatar
antfarmer2
and pull the vacumme line of the cc vacumme pod.
Old Jun 10, 2015 | 11:20 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I found out that mousies had chewed a small hole in the vacuum line that went to the vacuum canister located under the driver's side headlight. That solved my intermittent problems with my 87's erratic behavior.
Good luck!
Old Jun 12, 2015 | 10:04 AM
volkswagens-for-life's Avatar
Agreed with above. Pull the cruise control first, and then shoot some chain lube onto the linkage and up the sheath for the throttle cable. It will make it butter smooth.
Old Jun 12, 2015 | 10:42 AM
don hall's Avatar
don hall
Originally Posted by corvetteronw
I found out that mousies had chewed a small hole in the vacuum line ......
Mousies? That's cute, Ron
Old Jun 12, 2015 | 11:59 PM
Cliff Harris's Avatar
Cliff Harris
Disconnect the cruise control cable from the throttle body to eliminate it as a source of your problem.
I had a throttle body hangup because I put the screw clamp for the accordion coupler on the linkage side and it interfered with the throttle cable.
Old Jun 13, 2015 | 12:18 AM
don hall's Avatar
don hall
In case you are not aware, Cliff is our C4 guru, so heed his suggestions. We are fortunate to have Cliff's participation, especially, when he lives in LaLa land - SoCal.
Old Jun 13, 2015 | 12:27 AM
Crossed Flags Fan's Avatar
Crossed Flags Fan
This problem is well known on certain model year C4s. See the attached. In the second section, click on the Complaints tab.
http://www-odi.nhtsa.dot.gov/owners/...rod_ids=202821
To question
