Starting issue
Tries every couple of minutes to restart and engine just turned over but would not even attempt to start. After roughly 15 min. of this it finally started and ran fine on the way home. Half tank of gas(Chevron). Thanks in advance for sharing your wisdom. SAVE THE WAVE
Then when I turn off car and try to restart security light foes on when I turn key on, but when I try to start security light flashes and engine just turns over. This is a on again and off again issue. I took an eraser and cleaned both sides of the key but problem still persists. Alright C4 garus opinions appreciated. SAVE THE WAVE
BruceK
Junior Member
My Corvette Photos
Default Won't Start Security and Sys Flashing
I have a 1992 Corvette. I installed a Vats bypass and it seems to work fine. However, occasionally it won't start and the security light and sys light flash when it won't start. I never know when its not going to start, so its very annoying. Usually when I go to start the car the security light is off, I noticed that sometimes the security light stays on and thats when it will not start.
I stopped using the power locks thinking it was may the alarm that was disabling the car from start, however I still have a problem when I use the manual locks.
Help!!!!!!!!!!!!!!! This is so annoying.
BruceK is offline Report Post Reply With Quote Multi-Quote This Message Quick reply to this message
Old 06-17-2009, 10:19 PM #2
rodj
CF Senior Member
rodj's Avatar
My Corvette Photos
Need to pull the codes
http://www.digitalcorvettes.com/foru...56&postcount=9
Will give you indication of faults present
rodj is offline Report Post Reply With Quote Multi-Quote This Message Quick reply to this message
Old 06-18-2009, 11:44 PM #3
BruceK
Junior Member
My Corvette Photos
Thanks very much for the repy. I was wondering if the codes would still be there, since it runs fine after it starts. I will give it a try when I get time next week.
Old 06-19-2009, 01:35 AM #4
VetteFreak91
CF Senior Member
VetteFreak91's Avatar
My Corvette Photos
Send a message via MSN to VetteFreak91
Check the battery voltage, it should be reading around 12.6v. Then check it when turning the car over. The light flashes due to general system faults. This light may flash if the voltage drops below 9v. The most common cause of this light flashing intermittently is an old or weak battery. Get the battery checked and re-charge or replace the battery if necessary. If the battery is OK then check the computer for codes because one or more of the electrical systems may have a problem.
Good luck
VetteFreak91 is offline Report Post Reply With Quote Multi-Quote This Message Quick reply to this message
Old 06-19-2009, 08:00 AM #5
jimg's'93
CF Senior Member
jimg's'93's Avatar
My Corvette Photos
Send a message via Yahoo to jimg's'93
Mine does exactly the same thing...I never know when she'll fire up or not and I simply wait out the 10 minutes and most times all is well. Odd thing is it only happens in the summer (Hot) months but never when it's cooler out.
I've checked the voltage, connections, etc. and all is well. Since she's not a dd, I've just kinda learned to live with this PITA annoyance.
<<< Me waiting the 10 minutes out.
jimg's'93 is offline Report Post Reply With Quote Multi-Quote This Message Quick reply to this message
Go Back Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
https://www.corvetteforum.com/forums...post1574918379
http://corvettephotographs.com/c4vettes/codes.htm
What they mean:
https://www.corvetteforum.com/forums...post1576116036
look at the alt too.
SAVE THE WAVE
