heater problem
Old Jun 19, 2015 | 09:26 AM
bigtee95vette's Avatar
bigtee95vette
Default heater problem
I have a 95 LT1. In order to get any heat, I need to put the temperature setting to at least 30C (86F). Is this a thermostat problem?
Old Jun 19, 2015 | 09:32 AM
antfarmer2's Avatar
antfarmer2
What is the outside temp? Might be the inside temp sensor.
Old Jun 20, 2015 | 12:43 AM
Cliff Harris's Avatar
Cliff Harris
Definitely not a thermostat problem. The thermostat sets the minimum temperature of the coolant.
You might have a blend door problem. Do the HVAC system diagnostics:
To heater problem
