Blower control module oem 16061602
There's maybe Cadillac, Buick & Olds modules that will work if you've access to the salvage yards. If you're buying NEW do it local with the understanding that if it's not a match you don't buy.
There's maybe Cadillac, Buick & Olds modules that will work if you've access to the salvage yards. If you're buying NEW do it local with the understanding that if it's not a match you don't buy.[/QUOT
Seems most of the vehicles that used that part have been recycled by now. But the modules are available on line and there is quite a price difference between the two types. The 16061602 is less money. I bought the car two years ago and noticed the module was unplugged at that time and discovered the problem when I connected it. I'm thinking of comparing the digital controls next, they may give me clue also.
There appears to be some web-sites listing wrong cross reference part numbers for the blower control modules.
The blower control module used for 86-89 Corvettes powered the blower motor and was also used to engage the AC compressor clutch.
Starting in 1990 Corvettes the blower control module only powered the blower motor. The ECM or PCM was used to engage the AC compressor clutch.
I would assume the 90 and up modules used on the Corvette don't have the AC compressor clutch circuitry.
This is a picture of the blower control module from my 89.
Thanks for the info Hooked. I can finally put this part of the problem to bed but unfortunately while investigating the wiring harnesses feeding the module, I found either an error in the GM service manual wiring diagram or at the 4 pin female plug which has two wires reversed. In section 8A electrical diagnosis cell 66 pg 8A-67-01 at the bottom left of the wiring is reversed at pins"C" and "D" car has grn/yel at C2-D and blk at C2-C whereas the manual shows them swapped. Now I wonder which is correct? Could you check the plug on your 89 and see? Thank you.
Perhaps someone else with an '89 FSM will check and confirm. It might be interesting to have a couple '89 owners confirm the pin-out on their car.
Even the '90 & '91 C2 connectors show C as being "black".
What might be interesting is to compare the diagnostics that accompany that 8A section to see how they might compare to the pin-out. The programmer is different for '88 and '89 so who knows what's up. It might be interesting to compare maybe an '88 pin-out also on the car.
Interesting that you were that thorough in your inspections. I believe that some of the BMC modules that serviced multiple years had unused circuits and unused pins in some of the connector faces.
On 90-96 C2 pin C Black wire is ground. C2 pin D is not used.
Appears the prior owner installed a late blower control module and
moved the Black wire from C2 pin D to C2 pin C which appears should get the
blower to work but I don't know if the the AC compressor clutch would work.
If the blower motor runs when the ignition key is turned On and you have no control
of the speed, verify the fuse mounted to the firewall inside a black relay type housing
isn't blown.
Usually if the blower control module is bad, the fan runs even with the ignition off.
Below diagram shows the C1 and C2 connector wires for a 89.
OR
maybe confirming that the pigtail isn't a cut/splice added in a service repair attempt by going deeper into the conduit looking for evidence.
Here's a diagram for the 89 and 86 pin outs.
Notice C2 pins C and D are labeled different between these two years
but the actual control wires are wired the same. Only the alpha pin out lettering for the connector is different and possibly the color of the wires.
My guess would be connector C2 alpha pin outs for 86 and 87 are the same.Not sure about a 88 and 89-96 have C and D swapped. In the Original posters case if some one installed a 90-96 Blower control module in a 89 they would move pine C2 pin D to C2 pin C. This may get the blower to work but probably not the AC compressor since the AC clutch control was done by the ECM or PCM for 90-96 and not the Blower control module.
Post what the C2 alpha pin out is on a 87.
Not sure what the exact differences between the years on the older control heads are.
Firmware and how you get into diagnostic mode may be different. Some one did mention
getting in to the diagnostic model is a different button sequence from a coupe and a vert?
The '90 FSM uses the same 12052023 with C & D swapped from your image that shows the similar connector but NOT part #'d.
Your part #'d 12052023 in a '90 FSM is orientated just like your NON part #'d that mentions '89 - '96 BUT in a part #'d image C and D are swapped.
I had trouble putting my hands on the '90 FSM. Here's the '90 C1 & C2
Attachment 47895747
The couple pages following the wiring diagram for diagnostics it would seem are very important to sort first hand. An '88 diagram is the same as an '89 from what I've been able to see but I have neither FSM to read the diagnostic aids and troubleshooting section.
Note: All air passes thru the evaporator core. The air then is deflected by the blend door. The temperature setting determines how much of the air passes thru the heater core or bypasses it.
Unplug the two pin connector at the blower motor.
Turn the ignition On.
Set blower speed to 10.
Measure the voltage at the Connector.
Purple wire is the voltage for the Blower motor and Black wire is ground.
Should be 11.8 or higher.
If you set the blower speed to 1 voltage should be around 4 volts.
This tells you the voltage sent from the AC Programmer is correct and
the Blower Control module is providing the proper voltage to the blower motor.
If the results are correct, remove the blower motor and manually spin the
squirrel cage. Should spin freely. You can also apply battery voltage the motor
and observe how well it spins.
Look inside the hole where the blower motor was.
Verify the Evaporator core is not clogged with dust and dirt.
If your complaint is the air is not coming out of the proper vents.
You need engine vacuum for the air deflection actuators to work. They direct the air
to the proper duct outlets. If you start the engine and select different air outlet positions and the air flow doesn't come out of the proper ducts could be the vacuum check valve located near the power brake booster area is bad. The vacuum check valve provides engine vacuum to the cruise control servo and the HVAC Programmer.
Here's a picture of an after market vacuum check valve. The factory one is all black and the shape is different. The check valve has a single input with two outputs.
Here's a thread that shows a clogged evaporator coil.
https://www.corvetteforum.com/forums...rator-out.html
Here's a picture of the duct work.
Turn the ignition on.
Measure the voltage at the connector.
Purple wire is the voltage for the blower motor and black wire is ground.
This tells you the voltage sent from the ac programmer is correct and
the blower control module is providing the proper voltage to the blower motor.
Verify the evaporator core is not clogged with dust and dirt.
to the proper duct outlets. If you start the engine and select different air outlet positions and the air flow doesn't come out of the proper ducts could be the vacuum check valve located near the power brake booster area is bad. The vacuum check valve provides engine vacuum to the cruise control servo and the hvac programmer.
here's a thread that shows a clogged evaporator coil.
here's a picture of the duct work.
