c4 dextron III
Old Jun 24, 2015 | 09:51 PM
Bill Jennings's Avatar
Bill Jennings
Default c4 dextron III
On a C4 95 stock base lt1 is dex III or IV the only trans fluid recommended, shop manual doesn't say.
Old Jun 24, 2015 | 10:37 PM
cuengineer's Avatar
cuengineer
Not sure if it might have changed through the years, but the owner's manual for my 1988 Base Model says Dexron II as shown below. I personally use Dexron III though.
Dexron ® II
GM Part No...................................... ....................................... 1051855
Size ........................................ ........................................ 0.946 L (32 oz.)
Usage .......................... Automatic transmission and overdrive unit
Old Jun 25, 2015 | 08:48 AM
WVZR-1's Avatar
WVZR-1
III was introduced in '93 I believe and was used thru maybe '04 or so. There was never a IV spec but there is a VI spec and I suspect that's what you meant.
The compatibility of VI to III is often debated. I'll leave that alone. I've a DexIII vehicle and I use an Allison spec'd product that is DEXIII spec'd. Castrol Allison TranSynd
Old Jun 25, 2015 | 08:53 AM
enventr's Avatar
enventr
Are they still manufacturing Dexron 3 anymore?
Old Jun 25, 2015 | 09:32 AM
cuengineer's Avatar
cuengineer
Advance Auto has CARQUEST Oil & Fluids Dexron III/Mercon (ATF) Automatic Transmission Fluid (1 Quart) for $4.99/qt. I haven't used this though as I still have a stash of Dexron III.
Old Jun 25, 2015 | 12:36 PM
davewhtt's Avatar
davewhtt
Ive been using Mobile trans fluid in my 93 auto and red line for my power steering. Probably more important than the brand name is that you are changing your fluids all of them when needed.
Old Jun 25, 2015 | 12:53 PM
ColaBear's Avatar
ColaBear
2018 C1 of Year Finalis4
I run this in my 96 Auto.
Old Jun 27, 2015 | 09:21 AM
MavsAK's Avatar
MavsAK
I used Dexron VI mobil synthetic in my 89.
Still baby smooth shifts.
Old Jun 27, 2015 | 10:48 AM
c4cruiser's Avatar
c4cruiser
A good quality ATF that meets the DexIII/Mercon spec will be fine for GM auto trans vehicles. Most ATF synthetic fluids will also meet the Dex VI spec too.
To c4 dextron III
