L98 Plenum and Runner help
Old Jun 27, 2015 | 07:16 PM
89dd's Avatar
89dd
Default L98 Plenum and Runner help
Looking to pick up another set of runners and plenum to polish.
Are they interchangeable? I have a 1989 with casting #10108468.
Ebay has plenty available, with casting #s 10077151 and 14081006 but not mine.
What are the differences?
Old Jun 27, 2015 | 09:16 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Pretty good article from Hot Rod Magazine. A Google search will bring you much more.
http://www.hotrod.com/how-to/engine/...lassic-chevys/
Old Jun 28, 2015 | 12:19 AM
JackDidley's Avatar
JackDidley
Early runners have a fitting for a cold start injector. Later ones dont.
Old Jun 28, 2015 | 03:52 AM
Dt86's Avatar
Dt86
http://www.hotrodlane.cc/PDFFILES/TPIStory.pdf
Old Jun 28, 2015 | 04:49 AM
Joe C's Avatar
Joe C
Old Jun 28, 2015 | 07:44 AM
WW7's Avatar
WW7
If I'm remembering correctly the 89 plenum was a 1 year only item....85-88 had cold start injector, 90-91 was speed density..I believe you can plug the cold start injector hole to use it on the 89, but you may want to check first to make sure..WW
Old Jun 28, 2015 | 12:36 PM
ghoastrider1's Avatar
ghoastrider1
I am thinking my 86 has two vacum fitting back towards the fuel reg. I have ( I think) a 89 and it has only one vacuum fitting back there.
Old Jun 28, 2015 | 01:39 PM
86V's Avatar
86V
Just FYI. I just got done polishing my 86' Plenum and runners. I made the mistake of sending the stock Magnesium valve covers out as well. If the 89's are Magnesium as well, don't bother! The Plenum and runners look fantastic. But the Magnesium turns real quick. PITA. I just bought a set of quality covers to replace them.
Old Jun 28, 2015 | 05:12 PM
89dd's Avatar
89dd
Just installed a set of PML scripted valve covers that I picked up from another CF member.
Look smoking hot, but now the runners and plenum need some love.
Wanted to pick up another set so I can still drive the car then bolt on the polished set when finished.
PS
Thanks to corvetteronw and Dt86 for the helpful articles.
To L98 Plenum and Runner help
