Keyless remote programing
Old Jul 7, 2015 | 05:19 PM
JWASR64's Avatar
JWASR64
Default Keyless remote programing
The 1995 I bought didn't have the remote Dealer didn't one from the owner. If I boy a new remote can i program it my self.
First try resyncronizing your transmitter.
I don't have the owners manual:
But found this:
To match transmitters to your vehicle:
1. Turn the ignition key to ON.
2. Clear any warning messages on the Driver Information
Center (DIC) by pressing the RESET button.
3. Press the OPTIONS button on the DIC several times
until the blank page is displayed, then press and hold
the RESET button for two seconds.
4. When the message FOB TRAINING is displayed,
push the RESET button once. The message HOLD
LK + UNLK 1ST FOB in the DIC will be displayed.
5. Press and hold the lock and unlock buttons on the
first transmitter simultaneously for five seconds.
6. When a transmitter is learned (matched), the DIC
will display FOB LEARNED and then prompt you
to learn the second transmitter.
7. Repeat Steps 5 and 6 for the third transmitter.
8. Remove the key from the ignition.
The programming mode will shut off if any of following
has occurred:
You don’t program any transmitters for two minutes.
You take the key out of the ignition.
You have programmed three transmitters.
Thanks !
Old Jul 7, 2015 | 08:32 PM
Hooked on Vettes's Avatar
Hooked on Vettes
You can download the owners manual from here.
http://www.vadengmpp.com/owners-manu...t-Corvette.pdf
