need help with mystry rpo code
Old Jul 8, 2015 | 01:06 PM
barefootbob's Avatar
barefootbob
5th Gear
Default need help with mystery rpo code
hi I am new to you guys , I am restoring an 85 c4 z51 I have a strange rpo code that does not come up any where maybe someone could help ? it is rpo code 18m. would like to figure it out trying to keep it original to sell it as close to original as possible thank you for any insight
Old Jul 8, 2015 | 02:07 PM
kenpeindl's Avatar
kenpeindl
It falls inline with your color codes (13L, 13U, 15I, 152) but I don't see it on GM master RPO list anywhere.
Old Jul 8, 2015 | 02:35 PM
84wuzmy1st's Avatar
84wuzmy1st
I think 18M might be essentially related to the D84 code, just a redundant way of saying you have 2 tone paint scheme? I would have expected an 18U there but basically I think it still means the same thing, your paint should be Medium Gray Metallic on top and Silver Metallic on bottom.
Old Jul 8, 2015 | 02:40 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
The RPO codes used to be a sticky here and were compiled and updated by member Bogus. Send him a PM and I'm sure he will be able to send you a copy.
Old Jul 8, 2015 | 04:31 PM
aDigitalPhantom's Avatar
aDigitalPhantom
According to https://www.gmheritagecenter.com/doc...t-Corvette.pdf on page 51 it is Med Gray (Met) accent color.
Old Jul 8, 2015 | 06:02 PM
WVZR-1's Avatar
WVZR-1
Any 2 digit XXM is a MID BODY COLOR and the paint code is displayed at the bottom of the SPID label. In the case of the early 2-tones you'll notice that both the U (upper body) and the L (lower body) are a "match" and the actual accent color follows with an M prefix.
This car the L & U match at 7781 and the M 7719
The WA for the code 13 on the car is the WA7781 and the 18M is a WA7719
Old Jul 9, 2015 | 10:26 AM
barefootbob
5th Gear
thank you guys I guess that code is a bit redundant, i was mainly curious if it was an accent stripe or something .
To need help with mystry rpo code
