Few c4 issues
Old Jul 15, 2015 | 08:31 AM
Dalesc4's Avatar
Dalesc4
Default Few c4 issues
Hi guys
Starting to look over the project and
Found a few electrical things
1 indactors come on but don't flash?
Flasher can ?
2 wipers work on flat out only ?
Faulty switch ?
3 brake light Jamed on ?
Stuffed brake light switch ?
Thanks for your help
Trying to fix there's things before the strip for paint
Old Jul 20, 2015 | 11:45 PM
Mortsciguy's Avatar
Mortsciguy
DalesC4,
I noticed that none of the forum members have answered your posting. I am guessing it's because you seem to being using some form of short-hand we don't understand. You need to spell out what each and every issue is, when it happens, and status of the ignition/engine when it does or does not happen. Is the car sitting and running, is it going down the highway, or is it sitting with the key in the on position but not running configuration?
You have to help us help you. Specific questions get specific answers. Welcome, and good luck with your project
Old Jul 21, 2015 | 02:45 AM
Dalesc4's Avatar
Dalesc4
Hi thanks for the post I will re post and be more specific on the issues thanks for the heads up thanks again
Dale
QUOTE=Mortsciguy;1590094787]DalesC4,
You have to help us help you. Specific questions get specific answers. Welcome, and good luck with your project[/QUOTE]
Old Jul 25, 2015 | 09:21 PM
GQ-ROD's Avatar
GQ-ROD
Originally Posted by Dalesc4
Hi guys
Flasher can ?
Faulty switch ?
1- Check/replace your flasher unit with a long life one.
2- Remove, test, clean your wiper switch, if that does not work, check your ground wires for continuity, if good, check your motor/ if bad replace motor.
3-Check/replace brake light switch.
Old Jul 26, 2015 | 02:28 AM
Dalesc4's Avatar
Dalesc4
ThanksI found the brake light switch needed to
Be pushed thru the bracket a little and now all good
I checked the flasher (it was behind the beard box
I have stripped the car for paint
And door trims are away getting repaired
Will work on the other bits
When it's back
Thanks for all your help
Old Jul 27, 2015 | 04:04 PM
DGXR's Avatar
DGXR
Flashers are often found behind beard boxes
Old Jul 27, 2015 | 10:12 PM
GQ-ROD's Avatar
GQ-ROD
So long as you don't find bread in your beard box you are ok !! LOL
Old Jul 27, 2015 | 10:13 PM
GQ-ROD's Avatar
GQ-ROD
When it's back
Anytime, don't forget to post pics of your progress!
Old Jul 28, 2015 | 04:28 AM
Dalesc4's Avatar
Dalesc4
Have heaps of pics in a different post Starting the tear down for paint
To Few c4 issues
