C4 Vats Bypass
Old Jul 30, 2015 | 12:17 PM
vetteski87's Avatar
vetteski87
7th Gear
Default C4 Vats Bypass
I am a novice and I am in the process of the Vats bypass and cannot
get the connector module apart. All the help would be appreciated.
Old Jul 30, 2015 | 01:14 PM
antfarmer2's Avatar
antfarmer2
Why just not fix it?
Old Jul 30, 2015 | 01:19 PM
vetteski87's Avatar
vetteski87
7th Gear
http://i4.tinypic.com/105r528.jpg http://i4.tinypic.com/105r4w4.jpg
I can't get these two parts apart.
Old Jul 30, 2015 | 01:53 PM
vetteski87's Avatar
vetteski87
7th Gear
Old Jul 30, 2015 | 01:54 PM
antfarmer2's Avatar
antfarmer2
Just lift the clip with a small screwdriver and wiggle it out
Old Jul 30, 2015 | 02:22 PM
1993C4LT1's Avatar
1993C4LT1
yes, ant is correct. It was kinda weird when I disconnected it.
Old Jul 31, 2015 | 01:12 AM
Cliff Harris's Avatar
Cliff Harris
There is a square loop in the second picture at the top that slips over the bump in the other connector. Use a suitable tool to lift up that latch and the connectors will come apart.
Old Jul 31, 2015 | 10:12 AM
arbee's Avatar
arbee
Originally Posted by vetteski87
I would say that if you are unable to figure out how to separate the connector by looking at the two pictures you posted, messing with the VATS is maybe a bit advanced for you.
To C4 Vats Bypass
