Dash L.E.D's
Old Aug 20, 2002 | 06:12 PM
jtfrog's Avatar
jtfrog
Default Dash L.E.D's
On an 86 vette. are the LED lights replacable individually? I have on light out in the RPM Bar and one out in the RPM numbers in the lower right.
Frog
Old Aug 20, 2002 | 06:17 PM
scorp508's Avatar
scorp508
They are LCDs, not LEDs. Do you have just a single bar of color out on the gauges, or does it seem like that whole lower right is just 'dull'. If it seems dull then the lower right backlight may of blown. There are 4 bulbs in the dash that backlight it.
Otherwise you may have to try and find a 1984 LCD tachometer pane to replace it with (not always easy).
Old Aug 20, 2002 | 06:41 PM
jtfrog's Avatar
jtfrog
Default Re: Dash L.E.D's (jtfrog)
A couple of the bar graph lights are out not the hole bar as with the numbers in the corner, just a couple of bars
Frog
To Dash L.E.D's
