I have a 95 Vette and am curious about this. I Live in Florida so I'm always using the A/C which turn on the fans. I have a Dewitt's rad. My question is would the vehicle run cooler with a 160 dg stat ( fans are always on) Or just leave the stock 180 dg stat. If I use the 160 stat I won't have to reprogram the fans as it's always on.
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
no it won't run cooler. Your car will get up to the same temp it always does regardless of the thermostat
With your Dewitt radiator you have done all you can really do as you say your fans are running all the time with the A/C on. What temps do you run on rare occasion that you do not need the A/C on? (Digital gauge) My 94 has std radiator/180 stat and is ok in our FL temps although when the temp gets up near the 228 degree mark (fan kick in temp), it can get a little "toasty" in the cockpit! I have thought about the Dewitt radiator and hence the temp question.
Your car looks like a clone of mine except for wheels! Black in FL is a "hot" color. (actually)
Reason: whatever
I'm always using the air as I drive it only a few times a week. The temp ranges with a/c on hwy from 198 to 205. I never had the car up to 228. (No heavy traffic) I'm only living here 9 months but I'll turn off the a/c one day and try it. I also installed a B&M transcooler with all metal lines not one piece of rubber. The radiator cools down faster than the stock rad. The quality is amazing. Black is hot but I lived in NY and all I had was black .cars. My 2 cars I have are black but are always garaged
Thank you as I was not 100% sure because the fans are in on all of the time. People claim when they reprogram the fans to come on earlier and use a 160 stat the car runs cooler
your car could be 190-220 all the time and would be normal
When you use the a/c the fans run all the time no matter what the engine temp is. Really the engineers weren't stupid. The cooling fans are scheduled to come on ~228 degrees because that's the optimum operating temp for the engine. Running at 180 is too cool and above 245 or so is too hot. You can accurately check the temp by selecting the correct selection on the HVAC panel to see the digital temp. You just have to convert that number from Celsius to Fahrenheit. The analog gage isn't reliable.
All make a good point but with a 160deg you can take the risk of condensation is your oil. My 96 lt1 runs stronger when car is 195 to 210. With a 180 temp I run you can set the fans to come on at 215 and I never see more than 220 in heavy traffic.this is without AC on.i like me temps because anything hotter than 230 scares me cause alum heads warp at 245. Good luck stay safe.
On average it does, because youre giving the cooling system a head start by opening the stat earlier.
If you spent less than 20-30 minutes in the car, it'll be cooler running than before. If you drive longer, the temps will catch up and equilibrate right where they are now with the DeWitts.
i have a 96. I changed to 160 stat and reprogrammed fans. Mine runs about 20 degrees cooler now. I am in central Mississippi. Pretty hot and humid here also.
If the weather is like Florida then the fans are on all of the time and you did not have to reprogram your fans. If you drive around for an hour the temps are probably the same as mine.
That's not necessarily true. That statement is ONLY true, if your current cooling system is maxed out already, and w/the DeWitts radiator, I doubt that it is. IF you currently run "down against the T-stat", then installing a lower stat will likely lower your operating temps in general.
The cooling system should have more than enough capacity -especially for normal driving.
Whoa, whoa, whoa. 228*F is the optimum temp? Since when? Where is that documented? IF that is true, why did GM install a 180* stat, which allows the car to run at ~185 most of the time?
There IS no "optimum" temp (especially down to 1*F). There is a wide range that is desirable for many reasons.....many of which we don't care about, but OEM's do.
The misinformation runs rampant in this thread! So wait....water doesn't evaporate at 160*F? Indeed it does. Additionally, do we realize, people, that the oil temp typically runs higher than the water temp? There is no meaningful risk, here.
How have you determined that? I hope you didn't use the SOTP meter...
Fans come on at ~230. How do yours come on at 215??
Say WHAT!? Where did you come up w/that fun-fact? 245*F is "the number, huh? I don't think that is true. Heads (aluminum or Iron) can and do warp and lower temps, and they can and do also provide useful service having been subject to much higher temps as well. Again, there is no "magic number" the head warpage occurs at.
Guys. It doesn't take 20-30 minutes to warm the car to stat opening temps. It takes less than 10 minutes. After that, either the stat is managing coolant temps OR, the cooling capacity vs. heat generated. It has nothing to do w/20 minutes, or 30 minutes, or what ever minutes.
As I said above, the cooling capacity of any car should significantly exceed that of the heat generated by the engine in normal driving....and in reality, that is true. This is even more true, when we have changed our radiator to one with 1.5 x more cooling capacity. In that case, lowering the T-stat temp should drive down operating temps, provided there is airflow over the radiator (AC on/fans running, OR cruising at speed).
You are rude and thinks he's better educated than others. My fans turn on at 215 because I had it programmed to that setting. Or is that something else I don't know what I'm talking about I guess.
That is not the point I'm making. Yes it will immediately go to stat opening within 10-15 minutes most days in summer, however if you get where youre going before the engine gets really hot, it will on average run cooler with the lower temp stat.
When I ran with a 195, the car immediately goes to 195. At that point it will continue to heat up and usually pretty quickly to fan temp with the stock radiator, which I do not believe is enough given the lack of airflow over it.
When I ran with a 160, the car immediately went to 160, and then more slowly upwards, so the fans would never get to a temp to start before I got anywhere, so I would tell you the engine is on average running cooler. All I've done is given the poor C4 cooling capacity a head start.
If I ran 30 miles down the road it will end up at the same temps no matter what stat I run.
Then you might mention that in your post. The way that you typed it, implies that what you experience, is normal operation. It is not. Sorry that facts seem "rude" to you.
