felt headliner sagging
Old Aug 9, 2015 | 01:47 PM
redvetteman81's Avatar
redvetteman81
Default felt headliner sagging
Has anyone hear replace the headliner on their vette, and how difficult was it?
Old Aug 9, 2015 | 03:52 PM
antfarmer2's Avatar
antfarmer2
Just pull off the backer board rub all the old foam off. Go to joann's fabric and get the headliner. A few LIGHT coats of 3m spray glue one each side trim and put back with glue or velcro.
Old Aug 9, 2015 | 07:46 PM
Ozzstar's Avatar
Ozzstar
Here ya go man.....have fun watching the video. Ozz
Old Aug 9, 2015 | 09:30 PM
seu318's Avatar
seu318
3M Hi Strength 90 and Ozzstars instructions worked for me. Have not had a problem since.
Old Aug 9, 2015 | 09:43 PM
Indio Monk's Avatar
Indio Monk
Targa Top Headliner Repair - Corvette C4 - YouTube
Great Job! I noticed the one I just brought home today has some headliner sag. Thanks for all your videos. I watched the Rear shock one also.
Old Aug 9, 2015 | 10:06 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
except that it's 25 yr old headliner with no foam under it
Old Aug 9, 2015 | 11:48 PM
EVLGTO's Avatar
EVLGTO
Did mine the other day.
Old Aug 10, 2015 | 03:39 PM
Ozzstar's Avatar
Ozzstar
Nice!
Old Aug 10, 2015 | 03:41 PM
Ozzstar's Avatar
Ozzstar
You are welcome Indio...don't forget to subscribe so you won't miss any future videos - Ozz
Old Aug 10, 2015 | 03:42 PM
Ozzstar's Avatar
Ozzstar
The foam is not necessary, this method works and looks perfect! People on a budget can do the repair for less than $15 and an hour of time.
Old Feb 6, 2017 | 03:28 PM
nwalker's Avatar
nwalker
Two issues. NOT ALL C4's HAVE that backing in them. My '96 had something that looked like a thick fiberglass substance. During the attempted removal, it completely DISINTEGRATED, leaving me with NOTHING except a mess on the top that was almost impossible to remove.
Next. After ordering a replacement from one of the online Corvette specialty places, I installed it with the velcro, per instructions. There was probably TWICE the amount of velcro you used. After it fell off, I AGAIN installed it with INDUSTRIAL STRENGTH, HI TEMP velcro. It fell off AGAIN. I noticed you are in Delaware. In Delaware, velcro might be great, but in Texas, where we actually have some HEAT, velcro SUCKS. I still, at this time, have not RE-RE-Installed it, but I'm guessing that some sort of high-heat contact cement might be my only solution.
Old Feb 6, 2017 | 10:52 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
EVLGTO, where did you get the headliner with the logo?
Old Feb 6, 2017 | 10:56 PM
antfarmer2's Avatar
antfarmer2
This is a old thread but I used contact cement never even thought of using velcro. But if you want to use it contact cement the velcro.
Old Feb 7, 2017 | 08:59 AM
Renfield's Avatar
Renfield
Default And then there's quick and dirty.
Here's a thought for this zombie thread.
I used foam safe CA (for R/C planes) to spot weld the fabric in place. Didn't remove anything. It wicked right in and stuck.
Still holding after a year, which I cannot say about the headlight fix.
When I get out ahead of all the other stuff that has failed or is about to, I might revisit the headliner. But now that it's out of my hair, I don't notice it at all.
Old Feb 7, 2017 | 09:42 AM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
We will see how our repair holds up after sitting in the garage all winter. Here in Ohio, we have been having temperature swings, along with humidity swings. My garage is separate from the house. Dry but not heated. I do go start the car and let it run long enough to heat up inside and dry it out every once in awhile. It was the Ohio weather that caused it in the first place. Did the same to my 1991 truck we are redoing.
Old Feb 12, 2017 | 09:26 AM
FAUEE's Avatar
FAUEE
This is on my to do list for my 92. It's top is just bare fiberglass underneath, and I'd like to build a headliner for it.
My plan has been to cut a big piece of cardboard to fit the opening, wrap that in the padded headliner fabric available at a fabric store, then attach the cardboard to the roof. Contact cement seems like a great idea for that.
To felt headliner sagging
