car bogging when accelerating
Old Aug 14, 2015 | 08:03 PM
youmakemelaugh2's Avatar
youmakemelaugh2
Yes filter was changed. Gonna do the o2 tm. Thx! Hope it helps
Old Aug 14, 2015 | 08:22 PM
antfarmer2's Avatar
antfarmer2
Great me too make sure take care of the wire to make sure it's in a safe place.
Old Sep 23, 2015 | 12:40 PM
youmakemelaugh2
Default Car hesitation
Hello, I really need your help guys. My 85 vette is still having problems. I've replaced the fuel pump, filter, had the cat hollowed out, did plugs n wires, air filter, and o2 sensor. The car runs awesome when it's cold but when it gets to operating temperature it's completely boggs when you try n punch it. Please help, this is driving me crazy!
Old Sep 23, 2015 | 12:59 PM
antfarmer2's Avatar
antfarmer2
take your icm and coil and have them tested might try new thermal grease. and run it with the fuel gauge on it and see what the pressure is when it does it.
Old Sep 24, 2015 | 01:41 AM
Cliff Harris's Avatar
Cliff Harris
Originally Posted by 93Rubie
The automatic has a kickdown cable and they do need adjusted from time to time.
700r4s do not have a kickdown cable. They do have a TV cable, which has a completely different function -- it increases the line pressure in the trans when the throttle is opened.
Old Sep 24, 2015 | 03:14 PM
desertmike1's Avatar
desertmike1
OK guys! what is this telling us, for (1) he's in Closed Loop..
Old Sep 24, 2015 | 03:29 PM
antfarmer2's Avatar
antfarmer2
ok but teach me how to fix.
Old Sep 24, 2015 | 05:19 PM
desertmike1
Hello, I'm still having some kind of restriction on my 85 corvette. It's ridiculous. It's has great fuel pressure, I had the cat hollowed out today cause they said it was clogged. Still same issue. Check engine light is finally on but probably because of the hollowing of the cat? Please help
Possibly a Second Clue, OP you need to retrieve Codes..
Old Sep 24, 2015 | 05:26 PM
desertmike1
This is where I would retrieve stored Codes (if any) and Look at Engine Sensors, Also Things such as Head Gaskets etc, should be considered for the purpose of troubleshooting.
Old Sep 24, 2015 | 06:07 PM
93Rubie's Avatar
93Rubie
Brain fart, your right on that. I was thinking one thing and typing another.
Old Sep 24, 2015 | 06:15 PM
93Rubie's Avatar
93Rubie
You need to pull codes and go from there.
FYI, did this shop actually do a back pressure test to confirm it had a clogged cat? Removal of a functional catalyst is illegal last I checked.
Also, in a 1985 it has NO way to monitor if the catalyst is functional or not. So your check engine light is NOT on for that reason.
These cars have very simple computers any competent technician should be able to plug in to the ALDL with an OBD1 scan tool and read the sensor readings to determine if any are off of acceptable values.
IF it runs good when cold but not closed loop it is safe to assume the base engine is OK. Good compression any how. If no smoke from tail pipe the head gaskets are likely ok.
I'm theorizing that once into warm operation (closed loop) you are having issues with your fuel system operating correctly. Likely too lean.
Do yourself a favor, unplug the mass air flow sensor in the plenum after the air filter and see how the car runs. This will set a CEL but will (should) kick the car into open loop all the time and eliminate the MAF as an issue. The MAF and 02 sensors are critical sensors for proper engine operation once warm and into closed loop operation. Assuming 85's have a MAP sensor as well.
Old Sep 24, 2015 | 06:24 PM
bigtoys's Avatar
bigtoys
Newbie question...what is "closed loop"?
Old Sep 24, 2015 | 06:37 PM
  #33
93Rubie's Avatar
93Rubie
Once in closed loop ECM uses 02 sensor to fine tune air fuel ratio. IN open loop the ECM ignores the 02 and using engine sensor data inputs and programmed parameters.
BTW, to the best of my knowledge EVERY computer controlled engine runs in open loop at WOT.
Old Sep 24, 2015 | 06:38 PM
  #34
desertmike1
Closed Loop Control: simply means the ECM is no longer running a Pre written Script, but now relies on Critical Sensors in order to Control the Engines Fuel Schedule, etc. This may or may not be his issue! But as 93Rubi said; force the Computer into Open Loop and see how the Engine Runs, this may offer an answer to the OP's problem.
Old Sep 25, 2015 | 12:02 AM
  #35
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Maf?
Old Sep 27, 2015 | 01:58 PM
  #36
93Rubie's Avatar
93Rubie
Mass Air Flow sensor-Typically located after the air filter but before the throttle body.
Old Oct 1, 2015 | 06:30 AM
  #37
bigtoys's Avatar
bigtoys
I had a similar issue with my '95 after replacing intake gaskets and optispark. While re-checking my sensor connections, I discovered that I had not firmly reconnected the MAF sensor lead. I cleaned the connections and made sure the plug "clicked" onto the locking tab firmly. Problem solved!
Old Oct 1, 2015 | 11:34 AM
  #38
mwm1993's Avatar
mwm1993
I would get the car nice and hot and when it starts bogging down park it and ohm all the injectors. (If you want, ohm them when they're cold for comparison since it runs ok cold.) I'm willing to bet you have a few injectors that aren't firing when they are hot. This is a quick and easy way to possibly rule out the injectors.
I also agree with unplugging the maf and seeing if the problem goes away I've had these go bad and show similar symptoms before
Old Nov 28, 2015 | 11:35 AM
  #39
czarredd's Avatar
czarredd
If you unplug the MAF and problem goes away, does that mean a faulty MAF?
