C4 questions
Old Aug 15, 2015 | 12:21 AM
dzer's Avatar
dzer
Default C4 questions
I've recently been told I need to replace my valve cover & intake manifold gaskets. Someone told me to replace the injectors while the manifold is off. I spoke with a mechanic who is familiar with corvettes who said he rather have the existing injectors cleaned and re-calibrated. Which way should I go, clean and re-calibrate or replace with new aftermarket injectors ? Thanks a lot..........Dan
Old Aug 15, 2015 | 12:37 AM
HAD2HAV2's Avatar
HAD2HAV2
what year is your car?
Old Aug 15, 2015 | 01:37 AM
Kmcoldcars's Avatar
Kmcoldcars
Always supply pertinent information when asking questions. In your case you asked general engine questions. There are at least 5 different engines - 1984 crossfire, 1985 - 1991 L98, 1992 - 1996 LT1, 1990 - 1995 ZR 1 and 1996 LT4.
Old Aug 15, 2015 | 09:54 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
If they are older injectors they are not compliant with the newer fuel additives and the seals will leak. If the costs to have them cleaned and checked or a few are bad is half or more than a new set, get a new set and not have worries later.
Old Aug 16, 2015 | 12:26 PM
dzer's Avatar
dzer
Default whether to clean/recalibrate existing injectors
The 'Vette is a 1987 tuned port with what I believe to be original 50K injectors. Should I have them cleaned/re-calibrated at 1/2 the cost or replace ? What are the best (cost is important) aftermarket injectors ? Thanks.............Danny
Old Aug 16, 2015 | 12:29 PM
antfarmer2's Avatar
antfarmer2
Look into fuel injector connections and talk to John
Old Aug 16, 2015 | 12:56 PM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
Injectors are like tires everyone has there preference. I run Accel in my LT1 and 91 ZR-1 never had any issues with them.
To C4 questions
