Muffler date codes?
Old Aug 19, 2015 | 10:53 PM
DinoBob's Avatar
DinoBob
Default Muffler date codes?
For the NCRS guys; I have a chance to pick up a set of GM original mufflers from a 1986 for my own '86. My question is this: It seems like the part numbers match up; but are the mufflers date coded, and if so how do I read them? Thanks.
Old Aug 19, 2015 | 10:59 PM
WVZR-1's Avatar
WVZR-1
Post snapshots of the information. Different vendors use different formats for date coding, it's usually easier to actually see the information.
Old Aug 19, 2015 | 11:08 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Do you have a judging manual. If it's dated or judged it will be in there
Old Aug 20, 2015 | 06:01 AM
Joe C's Avatar
Joe C
original OEM mufflers are date coded. here's a pic of my (steel blue) 90's muffler part and numbering information. the bottom row of numbers, "6 1 170 0," and "3 2 170 0," are the mufflers date code information. the 170 is the Julian date (in this case, june 18th), and the "zero" is the year digit - as in 1990. the "6 1" and the "3 2" is most likely some production information - production line, shift, ???, etc..
my mufflers were dated june 18th (1990) - from what I remember, my 90 was a july car.
Old Aug 20, 2015 | 09:50 AM
DinoBob's Avatar
DinoBob
The mufflers I am looking at have date codes similar to these. The codes are 142 and 147 and the year code is a 6, so they were produced, by that logic, on May 21 and May 26 of 1986. My car was produced on Nov. 22 of '85. These will not pass muster in terms of originality judging, I suspect. They have to be dated within six months prior to the cars build date but not after, correct?
Old Aug 20, 2015 | 10:30 AM
Joe C's Avatar
Joe C
correct - it used to be 6 months, but I'm not sure about that on later model cars. GM doesn't like to keep inventory, and I would suspect most parts are within a month, maybe two. as I'm getting into my 85, I'm finding most everything is around 2 months. I haven't been involved with NCRS for years, so I really don't know the current guidelines. the 6 month thing is really a guide line. my 69 corvette had a water pump (original OEM) that was dated outside the 6 month window. no flames, but I'm glad I'm over that matching numbers stuff!!!
To Muffler date codes?
