pump delete why?
Old Aug 23, 2015 | 09:28 PM
canuck buick's Avatar
canuck buick
Default pump delete why?
My a/c is gone my air pump is disconnected why do i need a replacement bracket why not just a shorter serpentine belt?
Old Aug 23, 2015 | 11:10 PM
Cliff Harris's Avatar
Cliff Harris
The main reason is to keep the water pump turning in the correct direction. No water flow if it's backwards...
Old Aug 24, 2015 | 08:55 AM
jimmers's Avatar
jimmers
You can get a standard flowing pump to solve that problem.
Old Aug 25, 2015 | 01:25 PM
canuck buick
Still not quite sure why the direction would be changed. Right now I have no a/c pump or tensioner just running a shorter belt. the only reason I can see that I need an air pump delete is to hold the alternator in place.This was done by the previous owner. I now have a squeal and I am thinking of just making like an arm bracket that would bolt on to the alternator and then over to a one of the left over holes remaining from the removed air pump.
To pump delete why?
