C4 headlight size
C4 to h4 globe style lights
Can anyone tell me the size of the light
Does anyone make a replacment light to take a h4 globe
Dale
You're in the AU I believe so I'd maybe make sure I bought either in country or make sure what ever you buy meets the spec required.
I can't give you any "hands on experience" but there's many threads regarding them. I would consider just maybe the factory lamps and power them using relays that would allow you to improve the voltage at the headlamp to the alternator output.
There should be many good reads some not here on the CF.
Expensive but there are some quite nice HID options.
But it's your butt.
Either of these replacements will provide a much better lighting pattern and you will have a good choice of H4 bulbs to use. I used the Hella lamps when I had my '92 and I used 90/100W bulbs and there was no problem with the factory wiring.
I bumped mine up a bit live in the bonnies and want to see the deer and bear are really hard to see and don't move near as fast. I went with the relays and 12 gauge wire.
I went with the 90/100 flosser too I think your pushing your wire a bit far.
