Super Sensitive Horn
Old Sep 5, 2015 | 07:53 PM
Will_Smith80's Avatar
Will_Smith80
4th Gear
Default Super Sensitive Horn
Year: 1996
The left horn button is SUPER sensitive. It goes off and stays on when I lightly flick with my finger. The right side button is fine. I have to repeatedly hit the button to make it turn off. Suggestions on how to fix?
Will
Old Sep 5, 2015 | 07:58 PM
antfarmer2's Avatar
antfarmer2
New set of horn buttons just under $60 when I did mine on ebay. Or pull the air bag and block off that side and use the other. But they get old and brittle best to replace.
Old Sep 5, 2015 | 08:19 PM
Will_Smith80
4th Gear
How do I block the airbag so it doesn't go off?
Old Sep 6, 2015 | 01:12 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Pull the airbag fuse. Disconnect the battery. Remove the Torx bolts from the back side of the wheel. The airbag will lift right out when you disconnect its yellow safety harness. Lay it face down after you remove it.
This diagram might help you see what is in there:
http://www.parts123.com/corvettecent...50f&ukey=35794
Old Sep 6, 2015 | 08:07 PM
antfarmer2's Avatar
antfarmer2
And wait ten min and honk the horn for good mesure after the disconnect
To Super Sensitive Horn
