A/C Questions
Background: I had the Freon charged last month in prep for a road trip but didn't use it on the trip. The other day, drove it when it was foggy out and used the defroster with heat up to clear the windshield. When I got home, I moved the heat control to cold after shutting it off as it's otherwise been hot here. Yesterday I went to drive it, I had a bird like chirp and it barely ran when started.
While trying to track down the chirp, I found the A/C compressor was running while the heater control was on defrost and the temp was on the coldest setting, even when you first start the car.
First question: does the A/C normally run with the controls in those positions?
Second question: When the A/C is running, it chirps like a bird but only when the A/C is running. When it's not engaged, no noise. Is the chirp normally in the A/C clutch in a scenario like this or is it in the compressor?
Thanks for any help.
Paul
The "chirp"? I had one for nearly 200K miles with an R4 in a CK truck and I believed it to be the clutch. Compressors 'knock'!! If it's cold and runs I don't know that I'd mess with it. An 'air gap' issue I'd expect.
