Hot start
Old Sep 11, 2015 | 08:19 AM
onearmbob's Avatar
onearmbob
4th Gear
Default Hot start
My 1985 sometimes won't start right away if the temperature is above 200.I replaced the starter and that didn't fix the problem. I've been told that they run that temp normally. Any suggestions for me
Old Sep 11, 2015 | 08:24 AM
DinoBob's Avatar
DinoBob
Yes, 200 is quite normal. Why did you replace the starter? Does the heat make it crank slowly, or not at all?
antfarmer2's Avatar
antfarmer2
Check the coil when going bad they don't like to start hot.
Old Sep 11, 2015 | 12:06 PM
onearmbob's Avatar
onearmbob
4th Gear
Default Hot start
Originally Posted by DinoBob
Yes, 200 is quite normal. Why did you replace the starter? Does the heat make it crank snlowly, or not at all?
it would not turn over at all when the temperature was over 200
Old Sep 11, 2015 | 12:10 PM
antfarmer2's Avatar
antfarmer2
check your battery connection both sides grounds too. might be a bad cable or battery.
Old Sep 11, 2015 | 12:18 PM
onearmbob's Avatar
onearmbob
4th Gear
Default Hot start
The cables and ends are all new so is the ground straps I even have a Optima battery
Old Sep 11, 2015 | 12:28 PM
antfarmer2's Avatar
antfarmer2
does it have a fuseable link by the battery? Or a power block by it?
Is it trying to turn over or clicking?
Old Sep 11, 2015 | 01:19 PM
whalepirot's Avatar
whalepirot
I had lousy luck with three of those.
Old Sep 11, 2015 | 05:46 PM
DinoBob's Avatar
DinoBob
It's not the battery. It is a heat condition near that starter someplace. Check everything, and I mean everything, near the exhaust and by the starter.
Old Sep 11, 2015 | 06:39 PM
onearmbob's Avatar
onearmbob
4th Gear
Thanks for your time I'll tackle it again this weekend
To Hot start
