87 starter wiring pics
Old Sep 20, 2015 | 10:24 PM
jess's Avatar
jess
Default 87 starter wiring pics
Can anyone help me with the wiring that goes to the starter. Any help
would be greatly appreciated. Car is an automatic if that matters.
Old Sep 21, 2015 | 12:04 AM
Cliff Harris's Avatar
Cliff Harris
This is what mine looks like:
Old Sep 21, 2015 | 01:21 AM
jess's Avatar
jess
Thank you Cliff. That clears up a lot of confusion. Right at the starter location is a green wire with a small clamp that then continues with
a female spade. The clamp has a step with a hole that looks as if it would slip over a bolt. In addition there is a blue wire that ends with a female plug. Not sure where these two go.
Old Sep 21, 2015 | 06:46 AM
gerardvg's Avatar
gerardvg
Hi
Here is an image from my shop manual, its an 85 however they should have the same configuration. Apart from alternator and Vats.
Hope it helps.
Old Sep 22, 2015 | 12:38 AM
Cliff Harris
The green wire is the one at the very top of my picture. It goes to the coolant temperature sensor between spark plugs #6 and #8.
The blue wire is for the knock sensor.
Old Sep 22, 2015 | 12:51 AM
jess's Avatar
jess
Thank you very much Cliff
To 87 starter wiring pics
