C4 Fuel pump replacement
Old Sep 23, 2015 | 04:13 PM
zaydog3's Avatar
zaydog3
8th Gear
Default C4 Fuel pump replacement
Where can I find the upper rubber mount that fits between the fuel pump and pulsator?
Old Sep 23, 2015 | 04:51 PM
antfarmer2's Avatar
antfarmer2
just replace it with the proper hose that can be in fuel.
Old Sep 23, 2015 | 05:07 PM
WVZR-1's Avatar
WVZR-1
Are you sure you're not confusing the location of the pad? There would be a pad at the base of the "tree" but not one at the top of the pump to the dampner or the "tree". I've not had my hands on a single pump tree in quite some time but I don't recall anything there. Maybe you're confused by the construction of the dampener. I believe there's been a couple different serviced by different vendors and there were differences in appearance.
The pad to the base was a separate serviced part.
Do you have remnants of the part you're trying to acquire? Post a snapshot.
WHAT YEAR IS THIS CAR? I BELIEVE THE ORIGINAL '85 - '87 WAS VERY DIFFERENT FROM THE '88 AND LATER WHICH LATER REPLACED ALL.
I guess you just didn't "GET IT" - Try the question "one more time maybe".
Old Sep 23, 2015 | 05:18 PM
antfarmer2's Avatar
antfarmer2
yep maybe miss read.
To C4 Fuel pump replacement
