84 vette
Old Sep 28, 2015 | 03:44 AM
jpeters11's Avatar
jpeters11
Default 84 vette
Looking to buy some zr1 wheels for my 84. Was just wondering what back spacing for front and rear cause I know there are all kinds. And maybe a good website to buy some on or part numbers if possible. Thanks.
Old Sep 28, 2015 | 08:44 AM
WVZR-1's Avatar
WVZR-1
Here's VERY ACCURATE information for C4 wheel dimensions. I'd use these if I were you and if you found something of interest and had any questions I'd post back with brand/wheel and maybe a link to the product and ask advice.
I've checked and confirmed I believe nearly all of the dimensions referenced and JOBY is a frequent poster and user here on the CF
http://www.joby.se/corvette/div/corvette_wheels/
I'd consider maybe posting a WTB in the parts section and add your location in your profile so it appears in the information to the left.
Old Sep 29, 2015 | 10:03 PM
gerardvg's Avatar
gerardvg
Hi
The 84-87 9.5 inch wide wheels have 38mm offset compared to 54 mm offset for the 88-96 9.5 inch wheels.
The exception is the 11 inch rear wheels on the ZR1 with 38 mm offset. You will need one inch thick adaptors to fit the 88-96 wheels on a 84-87, 2x for the front 9.5 wheels if you are using the 11 inch rears.
Direct fit (no adaptor needed)
http://www.parts123.com/corvettecent...50f&ukey=16150
Direct fit ZR1
http://www.parts123.com/corvettecent...50f&ukey=10123
Adaptors to use 88-96 wheels, you can get them under $100 on ebay...
http://www.parts123.com/corvettecent...50f&ukey=10148
To 84 vette
