Installing trapeze straps
Old Sep 28, 2015 | 10:14 PM
HIHO's Avatar
HIHO
Default Installing trapeze straps
I have an 1989 coupe and am installing new leather seats and foam.
I got the repair kit today with the trapeze straps. How in the devil can I stretch them far enough to hook them. Is there trick or special tool needed.
Old Sep 28, 2015 | 11:09 PM
antfarmer2's Avatar
antfarmer2
did you get the right ones should be no problem
Old Sep 29, 2015 | 12:33 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
I had the same problem when I did mine. I hooked one end than clamped a vise grip pliers on the other end to help pull it over to hook.
Old Sep 29, 2015 | 04:15 PM
Hot Rod Roy's Avatar
Hot Rod Roy
I used a loop of heavy wire clamped in my vise grips. Hook the strap in the wire loop to give you a good grip on the strap. Yes, it's very tight! Antfarmer must be some kind of Texas muscle man (or he's never tried it)!!
Old Sep 29, 2015 | 06:12 PM
antfarmer2's Avatar
antfarmer2
I did do some horseshoeing but only took mine off my 94 and put them back sounds like they relaxed a bit in 20 years they were snug.
Old Sep 29, 2015 | 06:17 PM
HIHO's Avatar
HIHO
I tried the vise grip as as well with no luck, even had a strong younger guy try it with no luck. Ended up adding an "S" hook about 1 1 /2" long and finally hooked it. Maybe not as stiff as it should be, but better then before.
Old Sep 29, 2015 | 06:54 PM
whalepirot's Avatar
whalepirot
Originally Posted by HIHO
Is there special tool needed.
Yes, there is. Some kits come with it (used by upholsterers) but I wrestled, like others, and got it done.
To Installing trapeze straps
