Do I need to reprogram my computer?
Old Oct 3, 2015 | 01:02 PM
kleptopigdog's Avatar
kleptopigdog
Default Do I need to reprogram my computer?
Little info ,1994 corvette automatic , So far I've installed 2600 vigilante converter, 3:07 rear gears , exotic muscle headers with corsa exhaust and high flow cats . At what point do I need to reprogram the computer other than just for the speedometer ?
Old Oct 3, 2015 | 01:10 PM
ghoastrider1's Avatar
ghoastrider1
Did you keep the air pump and
EGR ?
Old Oct 3, 2015 | 01:13 PM
kleptopigdog
Yes.
Old Oct 6, 2015 | 07:58 AM
TorchTarga94's Avatar
TorchTarga94
You could honestly do a tune anytime you want, even on a completely stock engine. For what you have you don't necessarily need a tune other than maybe getting the speedo corrected from going to 3.07 gears. I think PCM for less will only charge $50 for a second tune if you ever added more down the road. Something to think about.
Old Oct 6, 2015 | 10:16 AM
John A. Marker's Avatar
John A. Marker
As noted above, you can have a tune done anytime to dial in the small changes that were made. The computer will compensate for your changes without too much of an issue.
You will positively need a tune if you change the cam to one that is different from the stock cam.
Old Oct 6, 2015 | 07:08 PM
kleptopigdog
It seems like my shift points are all over the place since the converter and rear end change,2:59 to 3:07.
Old Oct 6, 2015 | 11:10 PM
JackDidley's Avatar
JackDidley
The speedo needs to be corrected in the program. You have an electronic transmission so that could be important.
Old Oct 7, 2015 | 12:17 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
A custom tune for your engine will always extract the maximum.
I tuned a stock 86 with great results.
Later on with a few other changes the next tune was most impressive.
Find a good tuner now before you start making changes.
Old Oct 7, 2015 | 08:58 PM
chadk's Avatar
chadk
Have you looked at your TV cable and made sure it is adjusted properly?
To Do I need to reprogram my computer?
