94 Catalytic Replacement
My guy suggested the recommended OEM from MagnaFlo (not the barrel type) but they appear too long to fit under there without blocking access to the starter, etc.
He quoted me $500 for both, installed. Sounds reasonable.
FYI, engine is in tip top condition, changed O2 sensors, EGR at last smog check and barely passed the HC test so I knew I was going to have problems this time with the state lowering the allowable numbers.
BTW, how many miles on your C4???
https://www.corvetteforum.com/forums...1996-cats.html
$500 is not a bad price for the s**t you have to go thru to fit these in place.
When I put mine in there was no direct fit that was CARB legal. Magnaflow now has them.....
https://www.magnaflow.com/catalytic-...ornia/products
Checking the cost of the cats online that are compliant.....hard to believe that your installer can install (labor and materials being the two cats) for $500.
Betty Boop was a 95 with 150,000+ miles, and passed smog.
There are few little things you can do, and retry.
Ensure the PCV is good, air filter clean, fuel cap seals, ensure the EGR is working properly, and the most important drive at least nine miles before you SMOG it. Ensure those cats are VERY HOT for the test.
I used to leave the Vette running on the parking lot. These things are technically ancient, and to keep up with California's demands we got to learn how to play with them.
One last thing, if you choose to buy new cats, those aftermarket cats do not have heat shields. Do not believe they are not needed, if you go ahead and install them without heat shields you will feel the heat on your right leg right away.
The important thing is that per CA smog rules, the numbers have to go with the engine number of the vehicle. In other words, can't install generic ones without running the risk of it not passing and who wants those type of headaches. Other than that, the car is in perfect running condition. I just don't drive it much.
Two years ago my numbers read:
15 mph: HC Max-59, Meas-55/CO Max-.34,Meas-.20/NO:Max-484,Meas352
25 mph: HC Max-34,Meas-27/CO Max-.32,Meas-.20/NO Max-541,Meas 446
And that's with a well running engine.
But maybe I'll give it another shot before spending $$$. Can't hurt.
As a reference for anyone interested, MagnaFlow's P/N's are 332408/332409
.OK, those of you who work on your own cars, as I do, have a sense of how is is running. You know, a six sense kind of thing.
Let me begin by saying that the smog inspection place is not where I normally take my vehicles. This guy appeared to quickly access that I needed cats. As you all know I then took the cars to get new cats, well, you all know the story.
I just wasn't satisfied with this dude so I drove the car back to my own guy. You see, I work 40 miles away, don't drive in, take the train, so the Vette always stays in my area.
Anyway, this morning I take it to my guy, he runs the test and I pass.
He didn't do anything illegal but it makes me wonder how different each station is calibrated or if their testers are in working order.
It's like attaining a 2nd opinion from a Dr. Might be worth it.
So! A birthday gift to me today is that my Vette passed!
Perhaps I will use the $500 I would have needlessly spent on cats on new tires.
Or maybe it's time to sell her. I've only put 461 miles on her since the last smog check. Just don't have the time these days to drive her much.
Love her because everything works except the cruise control (cc is on a 6 spd anyway is beyond me).
