only a few issues
Old Oct 9, 2015 | 06:55 PM
darthvett's Avatar
darthvett
Default only a few issues
Hi all recently picked up an 1984 l83 vette. Heater works but sometimes only blows cold air? Picked up a new tps as the old one was shot and plan on cleaning IAC as well. Have an idea on how to set tps but there is suppose to be a screw to adjust idle. Is that behind the tps? Car is hard to start when cold and will idle to like 2k then settle to 1k idle. I don't think it's the temp sensor so that leads me to cleaning IAC sensors and replacing tps. Could the heating issue be a cracked heater core? No smell. Sorry if u have heard this before just new to a c4 and could not find answers. Thatnks to all who reply.
Old Oct 9, 2015 | 06:56 PM
DinoBob's Avatar
DinoBob
Welcome. I'd search the forum on both of these issues, they are fairly standard questions.
Old Oct 9, 2015 | 07:03 PM
darthvett's Avatar
darthvett
What? 😄
Old Oct 9, 2015 | 07:29 PM
confab's Avatar
confab
I don't know if this is the problem, and I don't have an 84, but I hear the heater control valve is a problem on our year C4's.
If it sticks? I would assume that could cause cold air only. On my car (85) it's on the passenger's side of the engine compartment, by the firewall, where the hoses enter.
Old Oct 9, 2015 | 08:22 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Re the heater, be sure the coolant level is correct.
Old Oct 9, 2015 | 08:34 PM
rsc337's Avatar
rsc337
Replace the IAC Valve then check TPS. IAC valve gets sticky and won't work,even if you clean it. It's not expensive.
Old Oct 9, 2015 | 08:37 PM
rsc337's Avatar
rsc337
Then check to make sure your getting proper voltage to the TPS. Search this site for the answers to your questions.
Old Oct 10, 2015 | 07:36 AM
darthvett's Avatar
darthvett
Thank you all.
Old Oct 10, 2015 | 08:39 AM
HlhnEast's Avatar
HlhnEast
Not sure about the digital HVAC controls but my manual '85 heater control valve is operated by vacuum. The valve is on the RH side and is an assembly of a control valve with metal tubes running from the firewall forward into rubber hoses. This valve will get sticky as well as having issues with the vacuum supply line. Find the valve and follow the vac lines looking for cracked or damaged lines. They are 30 years old. Have someone move the controls in the cab and watch the valve for movement. The highly expensive Corvette valve can be replaced by a mid 80s full size (with gauge package) Chevy valve after extending the rubber hoses. I did this and it works flawlessly at 1/4 the price. Search for the part number.
Good luck!
Old Oct 11, 2015 | 01:58 AM
Cliff Harris's Avatar
Cliff Harris
You might have a problem with the temperature blend door. It determines the temperature of the air coming out of the air ducts. It is controlled by the COLD - HOT lever with a cable. Check that out.
Old Oct 11, 2015 | 09:15 AM
hotmotorsports's Avatar
hotmotorsports
1st Congratulations on your "new to you" 84 Corvette and Welcome to this Forum!
It would be a good idea to get a Factory Service Manual (FSM). That would help you tremendously!
I also agree with DinoBob to do a search. You may find these issues have been discussed several times and it would be good reading anyway. There are always hints associated with responses. When that's suggested, we certainly don't mean to "pass the buck"...there's a lot in here.
Chuck M
To only a few issues
